Sickle Mower Allis Chalmers 82S
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Sickle Mower Allis Chalmers 82S
    Posted: 12 Oct 2022 at 3:49am
Hi
I am currently looking to adapt a side sickle mower on my D272. I have some quesion. Looking on the  Allis Chalmers 82S side sickle mower for D14 ( or D15, D17)
In transport position, to prevent the mower frame going down, due to the slight leak in the hydraulic distributor, or in the cylinder  I guess that there is a retaining hook by passing the cylinder.
I can't see it on the drawing.  Does there is a such device or another option to to block the cylinder in the up position?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2022 at 4:37am
A chain, attached to the outboard cyl mount, and back to the frame should accomplish what you want, just be sure to mount it to strong points and make sure it doesn't rub anything vital, when its tight...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2022 at 7:49pm
I have a 82S and I’m unaware of a transport position for the cylinder, the sickle bar transport via the hook rod through the sickle is the only one that I am aware of. Repairing the cylinder or replacing it is your best bet if it’s leaking that bad.
This page was generated in 0.157 seconds.
