SHOW YOUR "B" IMPLEMENTS!
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: SHOW YOUR "B" IMPLEMENTS!
    Posted: 01 Jan 2018 at 9:16pm
Thought it would be fun to start a thread where folks could share pics of their B attachments and or implements that were designed to be pulled behind and matched up to the B. I enjoy the little B! Snap coupler B pics from the back welcome!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 9:40pm
This could turn into a great information source for all.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 9:48pm
I have a set of inside rear wheel weights, all painted ready to go. will fit others besides the B, C, D10
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 10:05pm
A late dual belt sickle bar I had. I gave it to a family member because it had the small PTO shaft and was pretty clunky.
Edited by R.W - 01 Jan 2018 at 10:08pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 11:15pm
I have an identical mower to that one, but mine has a single "C" size belt to drive it. Also have a pair of rear wheel weights, but that's all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 3:09am
Those mowers that have a double bet drive are a #5 mower. That is an improved version of the B/C mower that has the big single belt. The #5 will also mount on the CA whereas the B/C will not mount on a CA. I have 2 #5 mowers that could make one working unit available. I also have many other implement for B tractors available, as well as parts for them.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 6:18am
I used a Oliver 2-14 Rooster Plow for a number of years.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 6:21am
A model "C" front bolt right on the B. You have to use the Grill from the C
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 7:31am
Simple video using the B/C Sickle Mower
[TUBE]gSFfAnkLBDQ[/TUBE]
Edited by Charlie175 - 02 Jan 2018 at 7:31am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:12am
Very nice. Creston....Don't u have a pull type No. 9 disc for a B as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:14am
Charlie175 Do u have a pic of the front of your B?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:16am
R.W....Great looking tractor.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:28am
I'm stil looking for hardware to mount a pair of plows to a B, if anyone has....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:41am
I mainly did it for something different and to be able to haul my D17 and B at the same time as the narrow fronts would overlap.
To truly to get it to work right, the "C" steering box would need to be used to get the right geometry. As I have it, it steered hard.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:43am
The B/C Sickle and plow are simple designs, either hand lift or with the optional hydraulic ram
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:47am
The B Monroe seat was an option you could get.
Sorry for the divergence
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 10:28am
Thanks Charlie
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 2:22pm
May not be what you want but I'm not passing up a chance to show off lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 2:23pm
Awesome! Keep it coming.
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 3:49pm
39 B with 6 foot mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 3:55pm
53 B with plows. I had problems finding the B tractor hardware so I used one from a donor C
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 4:03pm
rear blade made from plow beam
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 4:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 7:31pm
Found another one
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 7:43pm
Had to join in.  I hope a mower is considered an implement.  One of my garage queens.
Edited by Hubnut - 02 Jan 2018 at 7:44pm
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 7:44pm
Steve ill.....what is that big hydraulic cylinder?
Randy MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:12pm
AC pull type implements and non AC implements!
34 WC #477, 38 B #1935, 1-116 on steel, #8 7ft dbl action disc, #9 5ft dbl action disc, 295 Chainsaw
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 9:29pm
Steve, yes, I have a No. 9 disc. (But the only photo I have is of my 8N pulling it) It's a bit newer than Randy's (spring loaded adjustment pins), but it's a 7 footer, and I'm thinking it would be a bit much for the B if I wanted to do any aggressive tillage. Haven't had a chance to try it out yet with the B, though. I know at the farm where the disc is, (extremely sandy soil) the 8N struggles to pull it. Has power, but without any weights, it loses traction and digs itself in a hole very quick. Of course, it wasn't designed for implements like that anyway.
Here's a photo of my B. Mower and umbrella are A-C, plow is an Oliver 2-12 rooster lift, like was already mentioned. Pulls that plow very nicely in all soils, but struggles for traction in the sticky gumbo that plows like asphalt just a few miles west of me.
Oh, also, Steve...it's a '42 war baby. Well, supposed to be anyway.
Edited by CrestonM - 02 Jan 2018 at 9:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 10:08pm
Very cool Creston! My war B is a 42 as well it would be interesting to see what your sn is and what the AM dash number is on the side of your block....should be a -13 or -14...
This page was generated in 0.150 seconds.
