Shim Stock
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Topic: Shim Stock
    Posted: 25 Mar 2012 at 9:44am
I need to make some more shims for the pinion shaft cover on my B. Can you buy stock at the auto store or is there a cheeper/better way?
The joy is in the journey.
AC "B" and "WD" and "C"
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:42am
Fastenal, McMaster-Carr. www.mcmaster.com Machine Supply Company.
Hokel Machine Supply in Ames, Iowa.
Gerald J.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 11:13am
My favorite shimstock....some assembly required....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 11:54am
Hobby shops or hardware store with the K&S line can have an envelope of shim stock sheets, 4 x 5" maybe not big enough for a transmission case.
Gerald J.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:29pm
For the paper shims I like to draw them up in AutoCAD and print them full size, then cut them out like paper dolls while watching TV.  In a pinch, the paper ones can be used to replace the steel shims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 11:49pm
Brett, you work too hard. How about inking the end of a rod or rod cap on a stamp pad and then printing that on the shim stock as many times as needed, then cut out the shims. No need to measure and make a drawing. Or with thin shim stock just push it against the rod or cap and slightly wrap it over the edges and dimple the bolt hole. Could use gasket material or paper to get a pattern that way too. Cut it out and trace around it onto the shim stock.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 6:53am
Gerald:
For rod caps and other simple flat surfaces, you're right.  For other places like final drive pinion caps, steering quill housings, etc, it is still less work to draw them up (and good practice too).  Of course, if I was really trying to "work smarter, not harder", I should probably just put a spare steel shim on the copier and press go...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:40am
Brett,
I thought about the copier too. Still need the stock first. I have the originals so I will just trace around the originals.
