Serves me right I guess
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Serves me right I guess
    Posted: 21 Sep 2025 at 9:51am
Have owned and operated Deere, Allis, Perkins, IH and Cummins diesel engines on the farm for close to 55 years of memory. Was fueling the 7045 Friday afternoon getting ready to start cutting silage. Ever since last fall when we got it all fixed up tip top mechanical shape she has ran awesome. I was listening to it and thought this is one of the sweetest sounding engines of all I’ve ever had.
The first half a load of silage, smiling from ear to ear, suddenly I felt like a shudder go through the tractor. I slowed down and holy crap what a serious miss! Smoking (black) something awful. 😞
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 10:51am
Injector tip blew off ??  A pushrod has jumped out of place because the adjuster bolt backed off ?? are the two most likely.  Pay attention to the blow-by hose or remove the oil fill cap with the engine running. Bad puffy blow-by is a failed piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 12:00pm
Thank you. I’ll check it out, but I won’t be fixing it here. Beyond my facilities. Though I would love to and learn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 12:47pm
Also, a blown head gasket between two cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 4:50am
it almost sounds like it’s missing on more than one hole, so this might make sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 6:27am
Blown head gasket is (for me) an easy diagnosis.  No change in blow-by fumes. No real change in exhaust smoke. When cranking with the fuel shut off the cranking speed is up and down because you've lost the compression on two cylinders. Regardless, park it. I've had a couple blown head gaskets in the past that the operators must have ran for a couple hundred hrs like that and then the top deck of the block gets burned away.
Edited by DrAllis - 22 Sep 2025 at 6:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 7:38am
Oh it is definitely parked! I won’t run it like it is.
If no change in exhaust = blown head gasket, then it is NOT a blown head gasket. Dad was following me in case I hit a wet spot and it smoked so bad he thought it was on fire. It looks and sounds terrible. I did slowly drive it home, and will drive it on a hauler I guess. Going to be a few months.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 7:54am
The excessive black smoke sounds like a turbo failure, but that shouldn't normally cause a misfire.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 9:07am
Spun #5 rod brg is a possibility -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 9:37am
yeah even smokes and chokes at low idle so I don’t think it’s that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2025 at 11:52am
I suppose that it could also have some weird injection pump problem causing a misfire and over fueling. Like the Doc says, an experienced ear can tell you alot without even starting the engine.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2025 at 8:11am
  I had a chunk break off the turbo compressor vane on our 7060 and I could not believe how bad it run.
