Serial Numbers
BH Reinen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BH Reinen Quote  Post ReplyReply Direct Link To This Post Topic: Serial Numbers
    Posted: 30 Jun 2010 at 9:15am
Were are the serial numbers located on my B  WD and WD 45? Thanks      Bart
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 9:27am
WD/WD45 -http://people.clemson.edu/~wsmth/SNLocat/ACSN4.htm
B is by the shift lever and says Tractor No. BXXXX
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BH Reinen Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 9:34am
Thanks for the help    Bart
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 9:34am
 The B serial will located by the shift pattern on the transmission. WD'S are stamped at the left brake cover or the left rear of the axle housing.
Engine #'s  (B) located on flange where the engine meets the torque tube on left side.
               (WD) On the left side of the engine just under the hose running from the air cleaner to the carburetor.
