Print Page | Close Window
Serial Numbers
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=14542
Printed Date: 03 Feb 2025 at 2:05am
Topic: Serial Numbers
Posted By: BH Reinen
Subject: Serial Numbers
Date Posted: 30 Jun 2010 at 9:15am
Were are the serial numbers located on my B  WD and WD 45? Thanks      Bart
Posted By: MilesGray (CO/KS)
Date Posted: 30 Jun 2010 at 9:27am
WD/WD45 - http://people.clemson.edu/~wsmth/SNLocat/ACSN4.htm - http://people.clemson.edu/~wsmth/SNLocat/ACSN4.htm
B is by the shift lever and says Tractor No. BXXXX
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Date Posted: 30 Jun 2010 at 9:34am
Thanks for the help    Bart
Posted By: irlbeck A-C'S
 The B serial will located by the shift pattern on the transmission. WD'S are stamped at the left brake cover or the left rear of the axle housing.
Engine #'s  (B) located on flange where the engine meets the torque tube on left side.
               (WD) On the left side of the engine just under the hose running from the air cleaner to the carburetor.
