Seed Corn Cost ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Seed Corn Cost ??
    Posted: 09 Oct 2021 at 6:44pm
I've driven past multiple designated "seed corn" plots after their "harvest"Embarrassed . OMG, a week later the ground had enough green corn coming up like it was broadcast to be "green chopped" like we did for forage in the late '80's Cry . Seems like the loss of seeds should have a correlation  to the cost of your next seasons seed cost ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:21pm
No kidding - its sad how guys cant set the machines up right
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:48pm
Shelled corn just laying on top of the ground or tilled in? Don’t think I have ever seen any in this area do that in the fall, usually needs to be worked in.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:59pm
spam
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 8:14pm
2 fields were DEFINITELY on the ground, you could see every row of the corn head, the others were "tilled" though Confused. Seems like I've read that the harvester machines blow a LOT of materials out of their "bowels" ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 8:42pm
Green combine...Wink
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 8:51pm
1% loss in 200 bushel corn is 2 bushel, you only plant less then half a bushel generally for 30 to 40,000 plants per acre. If you harvest at 15% moisture you can have that much loss, butt shelling, at the head from any machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 5:33am
Red Combines here are as bad for replanting as the green, only those still running Gleaners are leaving fairly unplanted fields.  Notably there are Bean Fields north of here that have a 10% field corn growth in them, and corn that has enough beans to almost qualify as a second crop, ALL harvested of Green and Red Combines.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 6:54am
Most of the Seed Corn I've seen harvested was picked whole ear. Must have some butt shelling if they are leaving corn.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 8:11am
Thank you x 100!!!
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 1:27pm
i can tell; you guys have never been around seed corn.  the ears are terribe looking.  if it makes 30bpa; that's a good yield.  the seed corn companies have there own machines to harvest.    just head loss alone is unbelieveable!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 4:57pm
You HAVE seen the equipment  that harvests seed corn ??  About the "ONLY" thing Green on these units  is the engine LOLLOL !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 7:40pm
I agree with tomNE the Seed Corn I have seen around Schoolcraft,Constantine and Three Rivers Mi would not be anything a Farmer would be proud of. Reminds me of what the Old Timers called "Tucket Corn"!
