Scamp transaxle parts?
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Topic: Scamp transaxle parts?
    Posted: 16 May 2016 at 10:05pm
Just got an 8 scamp. Got it running, drove about 800' and transaxle stopped. Leaked oil then ran with no oil and have oval hole where bushing use to go. I can probably mill bigger then make big bushing to press in. But one gear looks rough. Anyone know if any parts are available or a place to try. Thanks
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 8:57am
get a pic of trans axle or mod or serial of trans parts should be around
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 6:24pm
If you can get a part number I can check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 12:33pm
Is this for sure a Scamp and not a "Scamper?" A scamp is the same as certain models of Simplicity Wonderboy and I might have something for one of them.
Edited by ACmowerguy - 20 May 2016 at 12:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 11:50am
It is a scamp 8. According to ereplacementparts.com gears aren't available. I may have to see about weld or braze and broach or mill after. I didn't see any tag or numbers but i didn't pressure wash it i just scraped around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 6:51pm
Well just because they aren't made anymore doesn't mean I or someone doesn't have them sitting around new and looking for a new home but I'd need to know exactly what you need. Any pics of the bad gear in the trans?
Edited by ACmowerguy - 21 May 2016 at 6:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 6:08am
Its two of the four gears the axle gear contacts (all four the same). Maybe the forward reverse system. I'll see if i can upload pic tonight. I hardly get on computer anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 6:10am
I believe it is 7/8" wide or long and 5/8" I.D. and 12 teeth
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 9:58pm
File size on my pics are too big
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 9:14pm
Sorry I've been away from the site a few days. Will check and see if I can find anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 9:41pm
Ist it # 31? If so, it is a differential gear. They are very common and I still got some new ones last year. They are used in the differential on all of the B-Series, 700, and 900 Series. I probably have a couple of decent used ones. Will check tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 9:45pm
Yes i believe that is it
This page was generated in 0.668 seconds.
