SC D15 II lift trouble, need help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: SC D15 II lift trouble, need help!
    Posted: 05 Apr 2020 at 7:02pm
My series II SC  D15 is giving me fits. Last year I thought the traction booster was stuck, wasn't sure. You couldn't plow with it, it would raise all the time. Couldn't adjust it to lower correctly. Even pulling disc it would raise it. Now if you start it, the lift raised and won't lower at all. Lever has no effect, lift lower or traction booster lever. It sounds like pump is working and won't shut off. Hopefully it will leak down enough I can unhook the plow. What would be causing this? Any help appreciated. Thanks Tracy
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:12pm
Is a 3pt or SC ? Linkage needs freed up or more tension on torsion spring. Torsion bar if 3pt.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 11:09pm
Mack, it is a snap coupler.This tractor worked great for several years. I don't use it much. Just started doing this on its own. What would make the lift all of a sudden just pick up as soon as tractor starts. Even with lift lever down? Why does both levers have no effect now? Thanks Tracy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 11:20pm
The traction boost valve is stuck causing the ump to never unload.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 7:21am
If all external linkage is free and adjusted properly, spool valve in pump could be stuck or linkage inside unhooked.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 9:33am
Mack, what is best way to free it up and or check it out? How does pump come out? Does this happen often? Thanks Tracy
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 10:13pm
Not too common. Remove linkage from pump cover, remove cover ( screw a bolt in threaded hole in front of cover to brake loose), compress spring along side of pump and install nail in hole of spring shaft. Remove cotter key and spring assembly. Get lift arms down if possible. Remove lube line, remove 3 bolts holding pump in. With a pry bar, pry pump loose. When it comes free, it will drop like a rock. Disassemble pump and clean.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2020 at 11:10pm
Mack, I will do this. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 5:34am
hmmm, I'm wondering if in Mack's list of instructions, shouldn't the first thing to do is drain the oil ? Assuming the D15 is the same as D14 , it'll make a mess of the floor......
just thought I'd ask... I know some things are obvious...but sometimes we get 'focused' and ,um, well, kinda...oopsy..... BTDT..
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 8:47am
Jay, yes we would drain oil first. Thanks tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 6:21am
when drained, be sure to put the plug back in...IMMEDIATELY !!!
no need to ask WHY  answering my phone while holding onto it was a BAD idea....Cry
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 6:41am
Jay, you certainly seem to have some interesting adventures!!
I left all three drain plugs out of the CA when I was working on its hydraulics to give it plenty of time to drain. I hung a big sign on it that said "NO OIL, NO PLUGS" to remind me to replace the plugs and add oil! Happily that worked.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 8:11am
I try NOT to repeat mistakes, always seem to make NEW ones though Big smileLOL
I cleared out a LOT of space in the shop next door, looks real weird to SEE the floor....
... mind you that's only temporary as 'someone' has already eyed the space...
