Safety wire
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: Safety wire
    Posted: 30 Jun 2021 at 2:47pm
I'm rebuilding a C engine and it had safety wire to secure the connecting rod bolts and the heads of the crankshaft mains.
Now that I'm putting it back together, I expected to go down to the local auto parts store and buy safety wire. None of them knew what I was talking about and none of them have it.
So, I'm wondering: Where I can get safety wire, and 2) Do people still use the practice of using safety wire, and 3) If they don't use safety wire, what do they use?
"People are human beings, produced by the society in which they live. You encourage people by seeing the good in them." ~ Nelson Mandela
Jim.ME View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 3:05pm
McMaster Carr, Grainger's, MSC, Fastenal, eBay, Amazon, industrial supply houses are some places that will have, or be able to get it.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 3:35pm
I've never put safety wire back inside an engine. Torque everything properly and let it go.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 3:44pm
they probably have it, they just don't know what it is, or as with a lot of the stores, they have given it some name no one knows, my O'reilly's down the street keeps it
Edited by JoeM(GA) - 30 Jun 2021 at 3:45pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 5:15pm
I won't put an engine back together without it. I have a roll and have the pliers to twist it.
Safety Wire Twist Pliers Fuse Pliers, 6inch Aviation Industry Grade High Carbon Steel Forging Safety Wire Twisting Pliers Black
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 8:24pm
I am a firm believer in safety wire. I believe the CE engine would need .041 Nichrome wire. The safety wire pliers are great but for a small job you can get by without them, the good ones are about $90. I bought a pair from HF and they were junk.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 9:20pm
If they are torqued, they will stay. If one is not torqued and wired, it will brake the bolt or wire eventually.                    MACK
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2021 at 2:35pm
Guess I'll post this link again;
When I rebuilt the engine for my NF 45 I had to use a WD block. Main bolts were originally safety wired. Bought the pliers and wire and learned how to do it. I don't think it was necessary but what the hay. You can see in the pictures there was a little learning curve, wire is cheap!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2021 at 8:56am
Just an opinion , but if Allis engineers done it - I would too
This page was generated in 0.107 seconds.
