S 16 New Holland / Arens |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42275 |
Topic: S 16 New Holland / ArensPosted: 09 May 2019 at 10:59am |
I need the drive sheave that fits onto the PTO on back of tractor . Origional uas a coupling splined inside and a double belt pulley that was welded to that - in the end abolt holds it onto the PTO .
Seems daughter in law borrowed tractor - rand it and link pin cam out and she kept running it until that drive unit was junk - Well I was going to weld on new pulleys but somehow I set it in a save spot so it would not get lost --- Have not found that spot again ! It is about a 4" diameter 2 belt unit - uses a 3/8" x 1 1/2" bolt to hold unit onto PTO shaft . Arens bought the New Holland line of lawn equipment and most things interchange
