Run @ 540 PTO RPM or faster when cutting? |
Page <123 |
| Author | ||
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 13 Jul 2011 at 9:44am |
As much of a allis person as I am the ignornce of some of the posters on here is about ruining the appeal of this site for me not to mention how far from allis equipment some of the topics are is crazy. Match the rpm's to the task. Full throttle on a silo blower would be a must but that is more of a excption than the rule. My 6080 has 9000 plus hours on it without a overhaul those didn't come from me rodding on it. Why didn't the higher horse power 426's last? To many rpm's that's why. I learned from my grandfather who used his C daily from the day it was new till he stepped aside in the mid 90's how to take care of equipment. He also has a D-17 with 11,000 plus hours on it. Something must have been done right there. He made a living with those tractors not just tractor shows a living. I also doubt most combines run full tilt 90% of the time unless you have a cart running with them try more like 70% of the time and that is like the silo blower stuation where you need the rpm's. Go ahead run full tilt it just makes for more organ donors in the salvage yard.
So long
victoryallis
| Sponsored Links | ||
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2336 |
Posted: 13 Jul 2011 at 9:54am |
Amen Victoryallis!!!
Lonn
Posted: 13 Jul 2011 at 10:20am |
I agree with you victory except on the combine issue. You have to run them wide open and load them down to rated speed in order to get full efficiency and not leave crop in the field. On a gasoline engined combine the governor can't hold a constant speed very well unless you open it up.
This topic for some reason has hit some nerves and I can't figure out why.
Wink I am a Russian Bot |
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 13 Jul 2011 at 3:33pm |
X2 plus the walkers and sieves are designed to work best at full rated engine speed. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
427435
Posted: 13 Jul 2011 at 3:38pm |
My dad would have done the same thing to me. He wanted the field done and didn't want the tractor lugging. That's also how the experimental tractors on field test were run. |
Mark
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 795 |
Posted: 13 Jul 2011 at 4:22pm |
Just so everyone understands how lame this argument of PTO speed is I took my hand held tack that came with a 72 all crop combine my uncle bought years ago and checked some pto speeds in relation to the tach on 2 tractors. I only have 2 540 tractors one is on the mower so I took the 720 JD diesel at the 540 PTO mark on the tach which is roughly 3/4 throttle the pto speed is 600 and full throttle the pto speed is 620. On the second tractor a 210 with the famous high hp 426 that doesnt last, yet this one has run 200 hp and we have never had a problem with it( but I digress) at the 1000 rpm mark on the tach the pto speed is 1100 which is roughly 3/4 throttle again, and at wide open the speed was just under 1200 about 1175. So this argument about running PTO speed, or not, who is taking care of there tractor and who isnt, what your dad taught you, and I dont mean any disrespect to your parents at all, in fact my Grandpa was a slow runner and his fits about a wide open tractor, which lead to other problems I wont get into here are advise given based on nothing . The pto speeds arent even correct on the tach its over running on both tractors immediatly, and wide open didnt change the speeds hardly at all, less than 10%. You guys must think that wide open on your pto is like doubling the speed. I have another 9 tractors here I can test if you like the rest are all 1000 except the 8050 which I can swith but my guess is the out come is going to be the same.If someone has a tractor they want to know the speed tell me if there is one here or close by I can test I will. Heres another point what did they do when they chopped corn, baled or did other pto work with a WD45 there is no tach, so what were your parents grandparents etc baseing an over run on?
DanD
Posted: 13 Jul 2011 at 7:20pm |
I find it amazing the controversy this post has caused. I couldn't imagine doing some jobs like blowing silage. chopping, or grinding feed at anything but wide open throttle. On the other hand other jobs like running a square baler or pulling a corn planter call for a slower engine speed. I'll post some links to videos. You'll see my father baling hay with a 630 John Deere with a pto rpm near 540, but that same tractor in a mounted corn picker running full throttle (this isn't much different in those old two cylinder Deeres). Then there's a vide of him grinding feed with a 1963 Series III D17 at wide open throttle with over 10,000 hours on it grinding corn with a Gehl feed mill that's been used twice a week since February of 1968. Apparently no great harm is being done. Then there's video of him combining with a Gleaner E, of course at wide open throttle which is goverened I think at a little less RPM than a D17 tractor. Finally there's video of him plowing with a 185...usually around 2200 RPM, not at the full wide open 2500 RPM. Of course I'm sure everyone realizes that wide open throttle on a tractor means the high idle goverened top speed. It's not like having your car in park and putting the gas pedal clear to the floor.
[TUBE]VVWS9gdaY3A[/TUBE] [TUBE]E-hCT0yVaRc[/TUBE] [TUBE]TtFeeF6XM9o[/TUBE] [TUBE]4u1s7ZD5ZS0[/TUBE] [TUBE]xQqC_Vcmx9c[/TUBE] Tell me what I'm doing wrong?! Edited by DanD - 13 Jul 2011 at 7:27pm |
Ryan Renko
Posted: 13 Jul 2011 at 8:05pm |
Lets all put a fork in this topic!!
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1568 |
Posted: 15 Jul 2011 at 1:14am |
JD combines and maybe others don't really have a throttle. It is more like a switch, they are either idle or wide open. There is no in between.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |
Posted: 15 Jul 2011 at 7:33am |
This is Stan's original post:
All comments regarding combines, silage blowers, lawn mowers, recutters, bailers... they're all irrelevant to Stan's posting. His was about a 540rpm PTO-driven rotary mower. As was posted earlier, comparing engine speeds of for-purpose engine-driven machinery (combines, lawn-mowers, etc) is irrelevant to the 540rpm implement. The answer to the question of WHY is found in history, and engineering design and economics. References to 'wide open' are improper terminology. Throttles and injection pumps have 'wide open' positions of 'full fueling'. These are GOVERNED engines, which by nature, are intended not only to limit engine speed, but hold it constant at a given speed. Governors modulate throttle position to maintain governed speed. A goverened engine will run at the desired speed with practically no throttle, when there is no load. As load is applied, engine speed will drop off slightly, and the governor will BEGIN to increase throttle opening (technically referred by governor and engine-management engineers as 'sag')... the engine will only see 'full throttle' from a governor when the load is substantial enough to require all that the engine is capable of providing. Once full throttle is reached, any additional load applied will slow the motor down BELOW the goverened speed, which is usually referred to by engineers as 'overload fall-off'. Running an engines of for-purpose machines is irrelevant, because the machine is designed only for that purpose, and the engine governance, and all driven loads, are appropriately ratioed to their optimal speeds by drive mechanisms therin. Engineers determine proper speed of all those pieces, assemble the drivetrain ratios, and then calculate the proper final drive ratio by comparing the prime mover's fuel and power curves, calculate performance lifespan and durability, and then apply the appropriate drive ratio, and set (now program) the engine speed governor accordingly. 540rpm PTO output systems on tractors have been well-standardized since the late 1950's. Prior to that time, manufacturers made implements intended to be driven by their OWN tractors. They Generally worked within the realm of ASAE standards of the mid '30's, wherin the common 540RPM PTO shaft operated at 540rpm +/- 10rpm, in a clockwise direction (when viewed at the output of the driving machine). Through the late '50's, the expiration of Harry Ferguson's 3-point patents (there were many) gave the ASAE the ability to publish a 'standard' of hitching geometry, and they 'categorized' hitching sizes to tractor size. At the same time, they published the PTO standards. Once that occured, agricultural manufacturers both on the tractor end, and in the implement business, went to manufacturing implements to allow compatibility with other manufacturers. Prior to the 60's, belt-driven implements were very common. Belt-driven implements fell in their own neighborhood based on belt speed (in feet-per-minute), and the operator had to calculate a reasonable speed based on knowledge of the prior drive machine (oftentimes a steamer). It isn't unusual, particularly after the late '30's for full-goverened speed to be bumped up... manufacturers did this as part of the 'horsepower wars' to improve package performance. When doing so, the 540rpm PTO's final gearing either had to be altered (to accomodate the resulting higher speed), or the engine had to be slowed-down, and the PTO output tested (think Nebraska Tests) at less than full-goverened speed. Manufacturers knew this would be a loss of performance-point (if the engine didn't create higher torque without the governed speed increase), however, it was a small price to pay vs. cost of tooling for lower PTO gear ratio. Manufacturers also had to contend with belt hp performance, but towards the middle '60's. the importance of belt HP to the agricultural market fell off- most belt-driven implements were designed around lower-power tractors, hence, high belt-hp wasn't an incredible selling point. That being the case, manufacturers didn't invest the engineering or production resources to alter belt-drive ratios, instead, they just left it as-was, and entrusted the operator to use due caution. As time went on, and power demands increased, and PTO implements got big and mean, full-governed-speeds increased, manufacturers finally started revisiting rearend designs, PTO drive concepts (Cockshutt's live-PTO!), and PTO drive ratios to optimize PTO output power, especially on the Category II and III machines. Agricultural engineers were constantly working to provide the highest PTO output numbers at the lowest fuel consumption and longest lifespan, it was not possible to make a drive ratio that yielded the desired output combination. After the '60's, ROAD SPEED was also a consideration, and tractors were made with gearing and maximum governed speed to provide faster transit times between fields. Amidst all this, was the implement manufacturer, who used the ASAE and ASME standards guidelines for selecting coupling equipment and calculating load applicability. Once the design was done, proper implement manufacturers documented their products so that the operator would follow guidelines on operation. Allis-Chalmers, for example, never made ANY implement, that didn't get passed to end user, without also being handed a book. This is why, when you look at a tachometer, that SOME have the 540rpm 'window' in the same vicinity as full governed speed... while others, it's not. How a person goes about using their equipment, is totally up to them, and totally determines how the driving force, and driven implement survive, and all the casual and catastrophic results that may occur. The performance suggestions and safety mandates of the engineers of the machine-in-use should be abided by if you desire to get best performance, lifespan, and safety from the combination. There is nothing wrong with telling another guy what YOU do, however, it is neither a wise nor honorable practice to do so without indicating that you're operating outside of the manufacturer's suggested realm, and it is an extreme disservice and liability to recomend to another a practice which occurs outside the envelope of the original design guidelines. It is one thing to have equipment damage or injury due to one's own actions, it is totally another to suffer damage, injury, or death as a result of ill advise. The damage to equipment and people can frequently be repaired, but the dead cannot be brought back to life. The loss of friendship is irreplaceable. I have nobody to blame for my injuries except myself, and I plan on keeping it that way. I would rather be the one injured, than to advise someone into peril. |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Posted: 08 Dec 2011 at 5:55am |
I had a great time reading all these posts. I will be smiling all day long! Loved it. Been there, done that. Super reading material!
TexasAllis
Posted: 08 Dec 2011 at 8:15am |
I think the conclusion is run your equipment at the manufacturers suggested speeds and loads. Companies pay engineers a lot of money and spend millions in R&D to get maximum performance out of equipment.
Brian G. NY
Posted: 08 Dec 2011 at 11:35am |
Apparently AuntWayne's Dad had removed the governor?
Well.....without a governor, he certainly wouldn't want to run with a wide open throttle!!
Every now and again this subject comes up and like the Capt., I have to laugh at some of the comments. It appears that many on here do not understand the operation of a tractor governor?
Steve Bright
Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
Posted: 08 Dec 2011 at 11:58am |
Don't know who is right or wrong but I never run anything on the PTO faster than the 540 or 1000 mark on the tach, But what do I know
Page <123 |
