Run @ 540 PTO RPM or faster when cutting?
 Post Reply Post Reply Page  <123>
jeffrey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffrey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 2:47pm
Try and blow corn silage at 2/3 throttle.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 3:49pm
Boy, oh boy, oh boy!!
' hard to believe the number of people who don't have any concept of the governor's purpose on a tractor. Opening the throttle lever on a tractor is nothing like "puttin' the pedal to the metal" in an automobile.
Full throttle is not necessarily "wide-open" throttle. For heavy work, the tractor is designed to run at full "governed" throttle. The governor keeps the engine speed at the optimum RPMs which in turn keeps the PTO running at optimum RPMs.
PTO powered equipment is designed to run at either 540 RPM or 1,000 RPM and generally, equipment should be run at either of those recommended speeds in order to operate efficiently.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 4:03pm
Kinda shows how many of our posters have either never farmed/worked an Allis or are just new to tractors. I farmed on my own for 28 years, plus having grown up farming to age 25 or so, and never heard of NOT running equipment at "full throttle" when working it, including sickle mowers, rotary mowers, and various other applications. Granted there were times when we did not run "wide open", but that was choice rather than fear of tearing something up. Of course I would not belittle someone for not running their 60-70 year old equipment fast when there is not a need for it. I had a couple of Olivers, 1850&1855, and they had a shiftable PTO, from 540 to 1000, and when I didn't need power I shifted up and backed off the gas just to save fuel!
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 4:13pm
When I swiched from baling square bales with wd45 to using 185 on a 14t baler, I noticed the knotters not moving as fast with the 185 as they did with the wd45. I am sure that my wd and wd45 pto runs faster than 540. 185 at 2000 rpms is suppose to be 540 and it just didn't work as fast as with the wd45. Maybe I am just simple, but that is the way it seemed. Bill
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 4:24pm
Just remember that if you over speed a rotating device by 10%, the forces involved are increased by 21% (including how far something may be thrown).  A 20% increase yields a 44% increase in these things.
Check the Nebraska test reports for hp at rated PTO speed for your particular tractor-------there usually isn't much drop off and sometimes an increase in hp from rated engine speed.
A 175 had 62 hp at rated engine speed and 54 at 540 rpm PTO speed for instance.
A 185 was 75 vs 71.
A 6060 was 64 at rated engine speed AND 65 at rated PTO speed.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 6:09pm
wow how such a simple question can piss some people off. Tractor running slower than designed will do more damage than a tractor running faster. Cut the speed of a spinning shaft in half double its size, is a rule of thumb. A faster spinning shaft has less stress than a slow one. When a manufacturer has a 540 or 1000 pto mark on the tack it means to not pull the tractor's rpms to below that point or be prepared for problems.When a tractor is dynoed its is full throttle pulled down under load to its rated speed, which gives the proper reading on the dyno. This is how the dealers or fools think that a tractor is making tons of power, dyno it at full throttle and not pull it down to rated speed (the 540 mark or 1000 mark depending on the pto) and the dyno reads big numbers. Seen a dealer try and convince a customer his 2-105 white was making 200+hp stock, I told the guy there was no way in hell a stock 105 could do that, I got in a huge argument with the dealer because he had no clue how to properly dyno a tractor. The throttle on any brand tractor goes to the end for a reason and if the company didnt think so it wouldnt go that far. To call people names because they are running a tractor wide open, I hate to say this but you are showing your ignorance of the situation.When I was a kid we use to use a gehl 99 recutter to grind high moisture corn from ear corn to the silo it ran 1000 rpm , my uncle had a xt series 3 we filled silo with that thing for years and it would play with that recutter, loaned it to the neighbor because his Case tractor had broke down and he needed 1000 rpm on his recutter, after a couple of days he was complaining that the XT kept boiling over, we couldnt imagine what the deal was because we never had such a problem, went down to see what the trouble was he was running the XT at 3/4 throttle making it labor and not flowing the water properly opened it wide open like we ran it (for years I might add) the tractor cooled right down and played with his recutter. Thus endth the lesson, to steal a phrase.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 10:28pm
This is getting heated and long. I use my common sense when mowing small sh*t and when I get into bigger stuff I watch my trusty tachometer with the 540 mark adjusting ground speed. Ramming the throttle wide open would be dishonor to what common sense our dad taught us. Ryan
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 10:47pm
Kcgrain has it right. In the Nebraska test the tractor is running at full rated speed and then the PTO is loaded to bring the RPMs down to 540 to simulate field conditions not throttled back till the PTO is running 540 with no load.
I guess what pisses us, or at least ME off is when someone who is ignorant about how to operate a tractor starts throwing around words like stupid while spouting opinions which are pure nonsense.
If you really can't think of a situation where a tractor should be operated wide open, take it off the trailer and hook it to a tillage tool. Or at least read your owners manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 11:02pm
I think this is why some tractors last many hours and others are beaten like rented mules!!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 11:17pm
PLEASE...
Everybody, go back and read the OP question.
There is no point in arguing horsepower against appropriate speed.  The implement is rated at 540, because the ASME COMPATIBILITY CRITERIA are all based on making equipment interchangeable between machines.  The whole purpose, was to establish design criteria so that IMPLEMENT MANUFACTURERS could make a good implement, that would be used between many different machines.
The machine was built to operate on a given PTO type, it had a given shaft size and spline count, was expected to be operated at the given RPM (1000 or 540 usually), and was expected to be brought no more than a certain amount of torque (the workload) and not more than a given amount of shock (hence, shear-pins).
Tractor manufacturers accomodate ASME PTO categories the same way.  They build a tractor, fit it with tires, gearing, and ballast according to the amount of tractive effort they're trying to provide.  Once that's all done, they set up the engine governor for however they feel will be most successful under those circumstances.  THEN they set up gearing that provides one or more of the common ASME PTO speeds applicable to that category.  They put a demarcation band on the tachometer to give a general indication of what engine speed yields the designed ASME PTO speed.
Then they put the tractor in your hands.
From that point, you pick your implement, and hopefully, you pick something that's a good match... i.e., don't pick a Category II PTO implement requiring 89hp, and put it on a Category II tractor that's only 55hp.  Likewise, don't expect a Category 1 540rpm post-hole digger... or your ground-man operator, to survive with it stub-adapted to a Category III 110hp tractor with a 1000rpm PTO.
Finally, don't swear by the premise that 'faster is better' or 'slower is better', and don't generalize postulation that stress on a given component at one speed is more, or less than speed at another.  Stresses given up in one scenario, are always met, and replaced with stresses from others.
Reason:  The engineers who designed the machine know more about what they were thinking and doing... than anyone else ever will.  As a frequent retrospective engineer, I face challenges left by engineering errors and presumptions, not only from original design, but changes that casually occur in manufacture, but worst, after modification by people who may have had a pretty good grasp for what was happening, but clearly did NOT understand the ramifications of how their modification affected other aspects of the situation.
If you want something to yield the safety, performance, longetivity, and durability intended by the original design, then OPERATE it that way.  That means, if the tractor's book says "Operate at xx for maximum power"... but the PTO device says "Never operate above xx", you'd better take the more conservative route of the two.
Next... Throw fallacy in the trash.  When an industrial or agricultural engine is designed, it is 'curved'.  That means, it is analyzed on a dyno for fuel consumption, torque, and thermal stability.  When they leave the factory, you can rest assured that the Owner's Manual will indicate the acceptable range of operation... and staying within those guidelines will provide the performance indicated in all curves.  They didn't 'design' it to be used to drive implements faster than the IMPLEMENT DESIGNER intended.  NO engineer would even THINK of doing that.
The comment about overheating due to insufficient RPM-  Bunk.  It MAY have happened, and you may swear by it, but I assure you that the reason has NOTHING to do with the engine being designed that way... it's because there's an UNDERLYING PROBLEM that needed resolution.  ALL cause of low-speed overheating on a LIQUID-COOLED engine can be traced to either compression leaks (into the water jacket, typically through cracks, a damaged coolant circulatory pump, a failing gasket, or a missing or stuck thermostat.  First condition, is combustion gases being forced into the jacket, and displacing coolant from the top of the cylinder head.  Remaining conditions cause overheating because draw pressure at the INLET SIDE of the water pump is too low to prevent cavitation... and coolant therefore is not able to absorb waste heat for extraction.  I guarantee that agricultural engine manufacturers DID NOT design and release an engine that would overheat at common ambient ranges when operated below some speed... especially for non-pressurized cooling systems.
And finally, the speed at which you set the engine speed lever defines GOVERNED SPEED, not THROTTLE.  At just off idle, you can apply a heavy enough brake load to the engine such that the governor will respond by opening the throttle all the way.   You may not get maximum engine rated HP, but this is because of the disadvantage indicated in the TORQUE CURVE.  Peak Torque occurs at the point where the cylinders fill most completely.  Peak horsepower, however, occurs where the coincidence of torque and RPM yield the highest multiplication product.  In reality, calculating PTO horsepower is irrelevant, because abiding by the ASME standard means you only need torque... the other variable is FIXED AT 540.  That means for every ten foot-pounds of torque you can find at the shaft, that equates to a smidgen past one horsepower.  100ft-lbs = 10hp.  500ft-lbs = 50hp.  If your implement is only strong enough to take 350ft-lbs, and you feed it 630, you'll be visiting either the morgue or hospital, and your machine will be in the workshop or scrapyard.
Now, as for running machines that indicate higher acceptable input speeds, the manufacturer rated them as such for good reason.  Machines like silage blowers NEED to run fast, they're designed and built to do that, and simply will not throw adequately if you don't... but they're RATED accordingly.  I suggest, however, that if you have a 1000rpm silage blower, and only a 540rpm-equipped tractor PTO, that you look for some other drive method, as your tractor engine will be hard-pressed to GET there, or if it does, will be screaming bloody murder to swing it's PTO at almost twice it's rated speed... and you'll likely not be able to get the engine to spin there without disabling the engine governor.
Finally, there are some machines that you simply CANNOT run outside rated speed.  First and most obvious- the AC generator.  540rpm = 60hz line frequency.  Try to spin the engine 'faster' to get 'more power', and you'll be burning up electronics, overspeeding electric motors, and generally wrecking stuff.  Likewise, running it too SLOW will generate power at too low frequency, causing motors to drag and overheat.
Laws of Man, when broken, will frequently get you a slap on the wrist.  violating the Laws of Physics and Nature will get you the death penalty, and there ain't no trial-by-jury.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 11:21pm
you guys have it completely wrong if for some reason you think you are doing some dis service to your tractor by operating it at full RPM.It was designed to do that, combines run wide open 90% of the time, where is the abuse in that? When my uncle bought that XT new in 1970 the dealer told him flat out to run it hard to break it in properly and he did just that , and that tractor which I now own is still running great.You guys are stuck in the 1920's by thinking that operating speed is abuse.Its just that simple.Abuse would be running your bush hog at full RPM and than working the tractor till its ready to die and not giving it some room to breath, but I have an AC bush hog you cant make a tractor beg that hard the clutch slips, or if you have shear bolt type the bolt shears. Does that mean every job for the tractor requires full RPM. .........well by no means are we saying that, common sence dictates speed, and in some applications like baling hay or picking corn you cant run full RPM nor do you need it, but in other jobs like grinding feed, chopping crops, blowers, mold board plowing anything heavy that requires power open it up thats how it was made you will never hurt it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 11:30pm
So ignore the factory tachometer and just bury the throttle at all time when using it under a load??
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 11:39pm
  The only reason I wouldnt run it wide open with the pto is because whatever your powering may not be capable of anything more than rated speed. In field work I run my tractor wide open and everyone else I know does too. We pull a 15' farmhand brushhog behind my 7050 or 7060 and have been known to cut down up to 3" trees by backing over them.  The clutches let you know when its had enough, but if our brushhog was anybetter than it is we wouldnt do it. Its 1000 pto though.
Edited by 7060 - 11 Jul 2011 at 11:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 11:44pm
Dave,the engine on the XT wasnt over heating beacuse of insufficient RPM or a design flaw by Allis Chalmers  that wasnt my statement it was over heating because the engine not being at full throttle was  not running at the HP needed to run the recutter, so the engine, laboring was generating more heat than the system was designed to cool. At full throttle the engine was  no longer laboring, wasnt generating the extra heat was flowing more water more air etc to remain cool. Also because this engine is turbo charged it proabably wasnt developing full boost to develop full power, at wide open the engine in its design was devloping the hp, boost, cooling capacity etc to handle the load.There was no internal problem with that tractor, none, not a clogged radiator, bad pump loose belt nothing the only difference was the RPMS and the lack of available HP for the job.I still have the tractor if it had some interanl problem it hasnt showed up since 1981 when this happened.which would pretty much rule out any such problems you stated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 12:18am
KC, please don't take it as insult, but I'm saying that from principle of thermodynamics and power-unit operation, this conclusion is a fallacy.  The situation you describe happens in diesel stationaries and railroad locomotives occasionally (I taught troubleshooting on it for many years, and addressed this directly).  There IS something wrong, and by increasing speed, you're simply masking the problem.  My great-uncle's '68ish XT plows, bales, mows, and throws silage, and we've NEVER had overheating problems under ANY circumstance.
Regardless, having cooling concerns does not justify overspeeding a PTO driven implement.  Allis never designed it's equipment in such a way that it couldn't be used within ASME compatibility.  That would be akin to a car manufacturer designing a car so that it couldn't be operated below posted speed limits, or a variable-speed drill to be operated at any other speed than full-grip.
There are many things that cause diesels to suffer light-load overheating.  Frequently an injector issue on just one or two cylinders, exhaust valves that aren't seating soon/solid enough, an improperly operating wastegate, or a control rack that isn't equally metering fuel.  The most humiliating, is an injector return pathway that is plugged.  IN any event, the result is the same.  Fastest way to narrow down that problem nowdays, is to start and run up the engine to about half-speed, and then take a walk down each bank (locomotive here) with a video thermography camera and look for one cylinder that is operating COLDER than the rest.  Then, find out why.  Once they're all running at same temp at half-speed, you'll find it's much happier through the entire band, and has much better manners and more spunk.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 6:12am
Wow, this topic has taken off. On my 7050 I only pull a 4x18 plow so I usually only run about 1,900 rpm. It has never overheated or poured black smoke or whatnot. I could use the XT but the 7050 is much more comfortable and I like having all that available power. I also have run the XT at less than full rpm pulling a 9 shank Krause chisel plow without problems but the tractor will lug in the tough spots so I normally run at 2,200 rpm. My Dad rarely ever runs a tractor at full throttle unless whatever he's hooked to requires it and he made it through a lifetime of farming without blowing an engine. I tend to run a little faster than Dad and so far after about 30 years of field work never have had any problems either. I think everyone here knows their equipment pretty well so that they know what they can do and can't. Some run fast and some run a little slower.
A combine should always be run at full throttle and not allowed to get below a certain rpm or you'll put grain on the ground but I think most people that farm know that.
Wink
I am a Russian Bot
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 6:50am
Let's all take a chill pill! Good Grief!!!!!
Edited by JayIN - 12 Jul 2011 at 6:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 9:14am
Dave, you dont have to worry abot me taking it personally, am always willing to learn something new, but I do know the XT has or had no problems in that sitation, other than it was not making full hp on a continuous bassis. If you ever ran a recutter its a heavy pto load like a dyno but it lasts for hours on end, rather than intermitant, like a hard spot in the field etc, so once the load starts its there for as long as you were grinding, which back than we would start it at 7 am shut down for lunch and start back up till about 4  so other than a small breather as the next wagon pulled in it was pretty much full load . The only difference between the 2 setups was one was full throttle and playing with the recutter, and 3/4 throttle and laboring on it. Now the out line you have decribed may have had something to do with it, but we have had no heating problems with that tractor in any situation other than a recutter at lowered rpms. Again not to beat a dead horse here, but I am not saying that every situation requires full rpms, but in a heavy load, the engine and implements were designed for full speed and you are not doing any damage to either by running it there. Nor is the engine or implements being damaged by a slower setting, a little common sence will go along way in this, every condition requires a different approach, but on the recutter full rpm was required . Its much like a semi tractor taking a hill if your pulling the hill in too high a gear the engine begins to labor the heat starts to rise, shift down a gear, bring the rpms up lower the load and the temp goes right back down. By some of your guys comments about full throttle settings hurting engines or being abusive is just so out in left field, if that was so there would be a million dead semis blown up on the side of any grade, becasue every trucker I know is going to have there foot in it for full power to take a hill. My last point here on this matter is again, if damage or abuse was occurring in full RPM the manufacture would not let the throttle go that far. Peace everyone.
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 9:16am
Great explanation Dave!....I appreciate the explanation from an enginerring perspective and common sense. From my experience I agree with you on every front. Also, I think we all can agree that there are instances where engines are "de-tuned" for longevity. One I know that has been discussed on this site in the past is the 426 in the N-6 combine. Where RPM's were dropped most often by private owners or AC mechanics who have them in for service and they had much more luck for durabilty stand point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 10:42am
I don't know what the OEM rpm setting for the N-6 was, but the 426 wasn't happy at the 2550 rpm setting of the 7080.  The engine was much happier at the 2400 rpm setting of the 8070.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 12:33pm
Dave, I'm going to disagree with you on the reduced speed overheating scenario on the XT. Like KCG is saying, opened the throttle and no more heating.
1. Fan speed and air flow across the radiator.
2. Coolant flow through the engine and radiator.
3. On a Roosa Master pump, when you load the engine down, there is a point that the metering valve is no longer limiting engine torque via the torque screw. The design of the rotor allows for torque backup. When the rotor slows, the charging ports are in register for a longer period of time so the leaf spring that limits the maximum travel of the plungers is what limits maximum fuel. This gives more fuel than what is controlled by the metering valve.
4. Timing. The injection timing advances with RPM's. Late timing makes any engine labor and run hot.
5. Turbo boost. Maximum boost requires exhaust flow from engine speed. Black smoke is not just unburned fuel out the exhaust, it's also heat. With more engine speed comes more air flow through the engine's combustion chamber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 12:57pm
In the case of your Loco with a cylinder not producing as much as the others, one dead or low cyl is reducing the maximum output from the engine, the operator then leans on the throttle more for a longer time. Fuel useage is up/economy is down. There again, pushing more fuel into it, more heat developed. Same load, engine not producing full power, RPM's down, more heat, taxing the cooling system....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 2:12pm
WOW !!!!!!!
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2011 at 2:18pm
Always run all my blower  tractors wide open , cause i hate unplugging pipes from an 80 foot silo ..
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 1:00am
I try to run my tractors at 2/3 throttle, lawn mowers always at full throttle but that comparing apples to oranges as stated above.  When run at 2/3 throttle you always have that spare throttle to play with but latley i'm guility of buying oversized equipment in the name of getting more done faster or so i think!   lol
1955 WD-45 with factory PS
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 6:59am
I keep seeing all of the discussion and remember 2 things Dad would kick my for (not the only 2 by the way) Running pto equipment over pto speed and not running full throttle on heavy tillage loads.  It worked for him on every tractor from a square back WC to the 8070 and many in between.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 7:29am
We put tachs on our wd's so as to run right on the money for pto. My NH haybine just got a $1000 wobblebox and that is the weak point on my machine plus it's not fun to change. I'am not putting more stress on it by running it faster than that I'll drop a gear first. And on our 45year old Massy baler says all over in the book to not run more than 540. Balers running faster have more momentum to do more damage. Now a bush hog or silage blower etc. would be a different story. I wouldn't be worried bumping them up a little. Thats just our practice.
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 7:57am
Originally posted by D17JIM D17JIM wrote:
I keep seeing all of the discussion and remember 2 things Dad would kick my [IMG]uploads/1/censored.bmp"> for (not the only 2 by the way) Running pto equipment over pto speed and not running full throttle on heavy tillage loads.  It worked for him on every tractor from a square back WC to the 8070 and many in between.
This is the shortest and best advice I've heard.Been doing that for 35 years and haven't any problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 8:46am
BStone...that's about as clear as it can get...I think the original question got changed a litte from PTO work to tillage work and your statment covers both!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 9:08am
Well to answer the original question, I run my 175D with the brushhog at the 540 rpm mark on the tach, throttle up as needed in the tough stuff, throttle back going down hills. I have done this for the last 7 years and probably could run the tractor without a tach as I can "feel" the correct range just by the sound and vibration. I've tried running faster, but I think it actually makes the cut worse and my fuel consumption just goes up. In rough conditions (rocks, rough ground) I throttle way back and the quality of cut doesn't change...and I stay more relaxed and in control.  Running wide open is just stressful to me.
 Like others have said, there is a reason the manual states "540" rpm. It was designed for that speed!  As for running full throttle, under load, speed is your friend...bearings can take a bigger load at a faster speed....as long as they don't overheat! I have no problem running non-pto jobs wide open as long as I am under load and need the power.
ALLIS EXPRESS!
This year:
