Rt angle gearbox |
Post Reply |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8300 |
Posted: 30 Aug 2024 at 6:52pm |
Old 7016 Simplicity. What is procedure to get cross shaft out? Down to bare shafts sticking out and don't know how to get snapring out of gear.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 82007 |
assembly starts at 14:50.
Steve... am i looking at the wrong thing ? I dont see a snap ring.. https://www.youtube.com/watch?v=ZLkO4f5CePc Edited by steve(ill) - 30 Aug 2024 at 8:00pm |
Codger
Orange Level Joined: 23 Dec 2020 Location: Utopia Points: 2041 |
Don't know if a hydrostat, or gear drive but here is a breakdown: |
That's All Folks!
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8438 |
What are you trying to do to bevel gear box
SteveM C/IL
That shaft he slipped in is larger dia where it shoulders gear. Mine has a wire ring. Looks like just drive shaft out of gear. I have a broken tooth gear box in running tractor and "good" gear box in parts tractor. The good box has a bad keyway on through shaft. The bad box has good through shaft. I thought I 'd just switch shafts but don't know the procedure
SteveM C/IL
...shaft just drives out of gear.....
Edited by SteveM C/IL - 31 Aug 2024 at 1:46pm |
Mikez
The ring is a pain in but you just work it out with a pick. Usually gets bent and should be replaced. And should not have to drive gear. The ring is what holds it. There was different shafts. Depends on whether it was a gear shift or hydro or variable speed.
Post Reply | |
