Roto baler table conveyor problem |
Post Reply |
TB63
Bronze Level Joined: 01 Oct 2023 Location: Lawson Missouri Points: 8 |
Posted: 01 Oct 2023 at 7:58pm |
I tried to get my roto baler working today after sitting for 4 years. The conveyor on the table will not engage.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8423 |
Welcome to forum
TB63
Thanks. I should have included more info. The last time I used it it became clogged up and I couldn't get it free.
Today I finally unclogged it and got the belts spinning but conveyor isn't working. I've tried pulling the rope to get it going. I'm not sure if the twine mechanism needs to be reset or if it is the clutch. Any help would be appreciated. |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4800 |
There is a replaceable wear piece on the dog lever that engages and disengages the pickup conveyor. When it gets rounded it causes problems.
TB63
Thanks Paul. I took a picture of the part I think you are talking about but couldn't load it on this page. It has a threaded hole in it like something should go on it.
PaulB
Yes: That sounds right. It has a wear pad that bolts on there.
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1196 |
Before mike finds the part for you, make sure the linksge is free. Stuff loves to set up after 4 years the latch plare could be frozen
TB63
Well the conveyor started working so I decided to try a few bales. After going about 100 feet the baler PTO stopped and the tractor died. Basically the same thing that happened 4 years ago. Then I thought the hay clogged it up but now think something else is getting it into bind. Any ideas?
dr p
Are the bale forming belts workly correctly? Sometimes the lower belt get caught by the upper belts . That can stall the tractor
TB63
I will check that tomorrow. Thanks
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8644 |
There's a brake drum on lower right side. Make sure that the brake shoes aren't rusted to the drum
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 7319 |
Use a bigger tractor!!
No, wait don’t do that! |
TB63
I did loosen the bolt on the brake before I started but I didn't check to see if the pad was rusted. It ran fine and rolled a partial bale before it locked up.
TB63
Hey guys. Thanks for the all the helpful advice. I was able to bale a few today. I took a brass hammer and tapped on the brakes and they popped free.
Post Reply | |
