Roper pump 3600……… |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Topic: Roper pump 3600………Posted: 11 Dec 2022 at 8:30pm |
Can’t seem to reduce the pressure enough, backed the adjustment bolt out as far as I dare, when closing valve on discharge the engine starts laboring way too much for my comfort level. Hopefully a ‘softer’ loaded spring is available from Roper. Anybody have experience with Roper pumps? This is 2” inlet, 2” discharge.
Codger
Posted: 11 Dec 2022 at 9:26pm |
Do you have a trash pump you are working with or a suction pump such as used for irrigation? Roper had their name on a lot of pumps, small engines and appliances for many years.
They didn't make everything marketed under their brand name.
That's All Folks!
Lars(wi)
Posted: 11 Dec 2022 at 9:59pm |
It’s a Roper brand name. Designed for fuels, oils, etc.
Codger
Posted: 11 Dec 2022 at 10:07pm |
Thanks. I can check with the local oil distributor for any type information. I did not know they manufactured anything to do with petroleum products.
That's All Folks!
