roll over plow |
acd17toy ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: USA Points: 718 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Mar 2012 at 7:17pm |
Going to use my 2 bottom roll over plow for the first time. how do you adjust it so that it does a good job of turning over the ground? still waiting on the manual for it to come.
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
I found the if you drive one side of the tractor up on a 6X6 blocks, you can adjust the plow to lay flat on the ground. With a roll-over you do that on both sides. If yours is like mine, the bar that the lock pin snaps into is adjustable for each side. When I changed my plow to a different tractor, the rear of the left side was not penetrating far enough, so I loosened the bolt and pivoted the plow to compensate for that. Each bracket has a slot for adjusting. Bob
