Rod difference on D12, ED40 gear box Why? |
John426 ![]() Silver Level ![]() Joined: 14 Aug 2012 Location: France Points: 304 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Mar 2023 at 5:17am |
Hi
Do you know why there is a difference on the indexing area on the 2 differents rod on the ED40 gear box, the same for D12 and othrers. May be the same for other tractors. ( D10, D12, D14, CA, may be?) On the 1st / 4th shift rod there is a flat area between the 2 indexing hole No flat on the 2nd / 3rd shift rod Why this difference?
Edited by John426 - 24 Mar 2023 at 2:08am |
no explanation for these 2 different shapes?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53407 |
Might be there because the flat spot is used to index tooling, so the hole below is exaxtly paralel to the notches above...
May be, but the 2 rods seem to work the same way, with a ball to do the indexing. So a hole is suitable and with a greater depth for the ball. So a stronger indexing in position. What would avoid the gear jumping out , may be?
