Rob on his D17
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Rob on his D17
    Posted: 09 Oct 2023 at 5:42am
Pulling at our local Heritage Festival, 5000 lb Class
Edited by Charlie175 - 09 Oct 2023 at 5:43am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 6:38am
I think it would have spun it out in high side !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 6:54am
Very dry hard track, wind was brutal this weekend.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 10:01am
Some of the tractor lineup from the show
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 6:04pm
Dr Allis you are correct it would have spun out in hi range, my mistake to think with the hard track that maybe a slower wheel spin may have gotten me a little farther. Really pleased with the power it made in 2nd hi. Oliver 88 with 38” rears got me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 11:25pm
If you're pretty sure it can handle high second, use low third. It is 5% slower than high second and gains you just a little bit more HP with 5% slower gearing. Low third was always my plowing gear with the governor tweaked so the engine made full load at 1850-1900 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 3:25pm
Thanks I will keep that in mind. Track was hard packed clay due to high winds that dried it out. I still think even in ideal track conditions she would have kept the rpm up. I appreciate the tip.
This page was generated in 0.039 seconds.
