Ring gear
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Topic: Ring gear
    Posted: 11 Feb 2025 at 9:27am
Can the ring gear be flipped over on a c allis with out a lot of grinding from the starter?
If you choose not to decide you still have made a choice.
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 10:04am
Rather than flip it over, you are better to take it off and turn it 1/4 turn. Some ring gears are tapered on the starter side, so you should keep that side toward the starter.
A four-cylinder engine always stops in one of two places (two pistons are the same position in the cylinder). Rotating the ring gear 1/4 turn will give you fresh "meat".
Are you sure the grinding problem is the ring gear and not the starter drive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 1:10pm
Has a new starter drive, the ring gear is worn.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 5:43am
It's $40 for a new one.  I wouldn't go to the work of splitting the tractor and then try to save $40.  Slap a new on in and be done with it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2025 at 12:36pm
AaronSEIA
I agree. This is a friends tractor. I'm going to tell him the same thing.
This page was generated in 0.176 seconds.
