Rigid AC 3 Point to SC Adapter
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 7:35pm
Edited by JimWenigOH - 04 Dec 2021 at 7:36pm
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2021 at 3:09pm
I have one of those also.  Not sure where I acquired it, but assumed it went on an Allis tool bar, such as for a rear mount cultivator.  Anyone else know what they were used for or attached to?
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 5:38am
They were designed to be put on a piece of 3 pt equipment to convert it to snap coupler and be left on the implement.
AaronSEIA
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 8:25am
AaronSEIA
That is correct, bought an Oxnard blade at auction once. It is a three-point blade, came with the adapter on it. I took it off so I can use the blade on the 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 8:49am
That is interesting.  Never actually seen one on an implement.  As it is a set width, it would only work on a 3-point that is that exact width?  Or can it be adjusted?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 10:13am
Most things have brackets clamped to toolbar so would have to loosen things up,assemble and tighten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 12:41pm
Dave, it's been awhile since I messed with one. I'll check and report back.
