Restored AC 7000 Maroon Belly
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 8:45pm
Keep those pictures coming! The more I see the more I like.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 9:39pm
I think there is supposed to be a trim piece that holds the floor mat right at the door opening...... Great job though. Trade a 200 for it??? Wink
Wink
I am a Russian Bot
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 9:49pm
Very pretty inside and out. Great job!
Dave in AB
Maroon belly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 9:56pm
Yes, I think I lost it. Anyone have one for sale?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 8:09am
Maroon Belly,
I must say that sure looks good to me. I am not a good judge of these series, as I am stuck in the WD series tractors. But I see great attention to details and fresh clean look to all the areas. I agree that having a project during this pandemic is a good thing to keep us busy and keep our minds busy too.
The tractor looks new to me! Really rattle caned the whole thing Wow your finger must be needing a break!:)
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 8:28am
I'd like to see more pics of the door shock setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 8:51am
Maroon Belly,
thanks. Actually, I do have a gun (not experienced) and since I wasn’t doing any large panels (body panels in front of cab are original paint), I worked small areas, then wet sanded larger areas before painting small areas and wet sanding again. The final coat, I did as large of an area I could and still recoat  wet on wet. Top and lights came off, windows and fixed door came out, all gaskets removed and a ton of Cleaning and masking done. I was amazed that what worked the best for removing overspray and light polishing was a clay bar treatment. I consider the clay bar to be probably the most important tool for restoring and maintaining paint. The original paint had darkened considerably, requiring polishing compound, clay bar and slightly abrasive polish like Nu Finish. Repeatedly. I hate re-painting faded panels in good shape. I always restore if possible. The paint job could still use more polishing, but that can be done later. These kinds of projects bring out the anal in me! Agco paint is expensive, but good paint. Did notice some variation in shades. Good luck finding maroon in stock that is still in decent shape. Best thing is to order in a 6pk for $15/can.
BTW, I have a OEM wd45 decal kit and new rear rim I would part with considerably cheaper than AGCO pricing.
Edited by Maroon belly - 04 Sep 2020 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 9:07am
[QUOTE=AllisFreak MN]I'd like to see more pics of the door shock setup.[/QUOTE
I spent a lot of time on this. The idea behind a door shock is that as door closes, it goes negative (reverses direction), helping to hold door shut and a little push to open. I tried to achieve that by adding the tubing. It would have to spaced further away from Door to really fully achieve that.
Tim NH View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 9:40am
I was amazed at how well your dash came out. I noticed your temp, fuel gauge and steering cylinder are different than mine. My 7000 serial number is 4967.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 9:51am
The front axle was exchanged with our 7010 years ago. We needed the heavier axle for loader work. I had the cylinder rebuilt and told them it was a 7010 cylinder. They said it was the ordinal 7000 cylinder. Gauges are original. Serial 4216.
BTW, notice the rivets around around injection pump knob.
Edited by Maroon belly - 04 Sep 2020 at 10:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 11:38am
Both of our tractors are 1976.  So at some point in the year they changed to different style gauges. All I can see is the rivets, not sure what you have changed.
 Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 12:42pm
 Tim
After years of yanking it in and out, the plastic cracked and I riveted in a metal plate.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 5:28pm
Well you did a good job fixing it. Have you found shifting the 3 speed if your over say 1050 rpm, the front end wants to come up.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 7:21am
Wow that interior looks great. Would you come do ours lol.
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 9:58pm
I took Tom's kit and mounted it where you did on 3 of my tractors. My doors didn't seal very well when I installed it on top.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 10:08pm
Does that pipe get in the way getting in and out of the cab? How much further out do you think it needs to be?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 11:31pm
Lonn I don't have a pipe on mine, I went straight to the door. That pipe might be a nice handle when a fella gets a little older.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 8:08am
the original idea with the pipe on the door was to get the cylinder at an angle to either stop moving or move back out as the door closes. This makes a huge difference on how the cylinder acts. Go look at a modern tractor door. Also, the door is capable of opening considerably more than original, and this one does, so pipe doesn’t get in the way and does make a good handle. Don’t think for a minute that I shaped that pipe. It was already that shape and I adapted it to the door. I would love to take credit, but I’m not that good.
Edited by Maroon belly - 09 Sep 2020 at 8:14am
