Replacing hand clutch
worldchamp19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Topic: Replacing hand clutch
    Posted: 24 Sep 2015 at 8:53pm
What is involved in replacing the hand clutch with section of a WD45 with the gear box from a WC?
Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2015 at 2:46pm
are you talking about just removing the hand clutch to prevent slippage?
you can bolt the clutch together by using 2 of the pto drive gears, or you can use a splined coupler from a wc trans to pinion shaft. several different ways to accomplish this. think you could probably bolt the clutch together if you weren't wanting to also lose weight
I don't think you mean put in a gear box in place of the clutch?
Edited by CAL(KS) - 25 Sep 2015 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2015 at 6:58am
Yes I was meaning taking out the housing. I saw a picture where they took out the hand clutch housing moved the wd gear box housing to rear axle and in front put a wc gear box and it was connected to the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2015 at 9:09am
wd/45 gearbox is one casting with the rear end.  you would have to remove the torque housing ( hyd pump and clutch section) and replace with wc bellhousing and transmission,  and couple it to the wd/45 input shaft then figure a way to seal the oil in.
a bunch of work to cobble something together that wouldnt be legal to pull anywhere.  in my opinion, not worth the time and effort
Edited by CAL(KS) - 26 Sep 2015 at 9:10am
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 9:50am
its legal everywhere I pull you can call me if you have questions six one eight three one four two seven four one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 10:31am
Your $$$ much better spent making the engine stronger.
This page was generated in 0.414 seconds.
