Replacing CA Water Pump |
| Author | ||
1955CA
Joined: 10 Sep 2018 Location: Ontario, Canada Points: 602 |
Topic: Replacing CA Water PumpPosted: 30 May 2024 at 4:53pm |
Hello everyone. First time I've been on here in a while. And first time finally got some time to work on my 55 CA again.
I got a new water pump from Steve@B&B and I got the tins stripped off, rad out, everything good so far. But before I go any further and screw anything up, how do I get this pulley off the water pump? Do I have to remove those nuts? I have never seen one like this before. I'd like too try and get this done tonight. And what are torque specs for the water pump bolts? Thanks, Shawn.
| Sponsored Links | ||
Joined: 11 Sep 2009 Location: illinois Points: 90822 |
Posted: 30 May 2024 at 5:24pm |
the 4 fan bolts hold the pulley on... those nuts are to adjust the pulley width... Just tap on the pulley side to side... paint and rust are holding it on..
if you have a belt adjuster on your generator / alternator, then those nuts on the pulley adjuster do not need to be operational.. Edited by steve(ill) - 30 May 2024 at 5:25pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 30 May 2024 at 6:21pm |
#1 get the pulley loose on the hub.
#2 hold hub and turn pulley 1/8 turn. That will allow the bolt heads to pass the divots in the hub. After the pulley is off, you can remove the bolts and get the 2 halves of the pulley separated from each other and get them to spin when together to allow fanbelt adjustment like it was meant to do.
Edited by PaulB - 04 Jun 2024 at 1:50pm |
1955CA
Posted: 30 May 2024 at 6:22pm |
Oh okay. So do I need to loosen the nuts before I try and knock it off?
Turns out water pump is okay. It's the thermostat housing gasket that was leaking, but no way to see it until I pulled it all apart.
But going to replace everything at this point. |
dfwallis
Posted: 30 May 2024 at 6:34pm |
The generator bracket has VERY limited range. I found that it was necessary to "fix" the water pump adjustment because someone had put a 1/2" belt on and I wanted to go back to 5/8". If not changing the belt characteristics, probably ok.
1952 CA13092
1955CA
Posted: 30 May 2024 at 6:36pm |
Mine is already converted to 12 volt with an alternator and I have adjustment there too.
1955CA
Posted: 30 May 2024 at 6:38pm |
I'm just hoping I get it off without damaging the pulley.
Need to get this thing to the parade on July first.
1955CA
Posted: 30 May 2024 at 8:17pm |
Everything came apart and cleaned up perfect!
Now what's everyone's opinion....RTV silicone on gasket surfaces with the new gaskets or no? EDIT: got ahold of two of my Cat mechanics and they said gasket only.
Edited by 1955CA - 30 May 2024 at 8:55pm |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 31 May 2024 at 6:31am |
I, personally, like a very little good old Indian head Shellac on one side of the gasket. It also helps hold things in place when assembling.
Les Kerf
Posted: 31 May 2024 at 8:13am |
As a youngster back in 1960's I watched my Dad smear Permatex #2 Aviation gasket sealer all over everything; nothing ever leaked. As a teenager in high school shop class my shop teacher told us that if everything is properly clean you don't need any type of gasket sealer and will never have any leaks. I then embarked on a mission for several years to clean everything properly and never have any leaks. I failed. Now, as I am instructing my 13-year old grandson how to properly smear Permatex #2 Aviation gasket sealer all over everything, I tell him "Some day, you are going to think unkind thoughts about me for doing this, but it won't leak during my lifetime".
dfwallis
Posted: 31 May 2024 at 11:48am |
I don't think it necessary with a new gasket and clean mating surfaces but I usually use permatex red (partly for color matching) sparingly on most gaskets. On the oil pan gasket (cork) I only applied it to the top cover as it was extremely difficult to get the gasket to align properly without first fixing it in place to the cover. No leaks at the bottom...yet...When I was a youngster I used the permatex brown tarry stuff (#1 rosin) on everything.
Edited by dfwallis - 31 May 2024 at 12:30pm |
1952 CA13092
1955CA
Posted: 31 May 2024 at 9:27pm |
So far so good. Had it out running. No more coolant leak and got the Pertronix ignition installed.
Only bad thing is now I think I have a valve issue, hopefully just clearance. I'll have to pull valve cover. It was popping before. You can here it in air intake breather. I was hoping it just needed a tune up, but still doing it with the electronic ignition. Any specific things I should look at or test? It starts perfect, but popping increases with RPM
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 03 Jun 2024 at 2:32am |
I have no idea Shawn, but if you don't get an answer soon, start a new thread with the popping sound. |
1955CA
Posted: 03 Jun 2024 at 7:31am |
Sure thing Ted. But not sure if I'll have time to look at it this week. I'm going to look at my manuals I have for it and see if they have the specs for the rocker arm clearances and timing and I'll start there. First thing I'll do is pull the valve cover and run it and see if there is a valve not moving or moving slower than the others. Hopefully it's nothing major. Was really looking forward to taking it to the big tractor ride July first this year along with my Ford.
Les Kerf
Posted: 03 Jun 2024 at 10:44am |
I recently pulled the valve cover on my Model C to replace the leaking Welsh plugs; just before closing it back up my sharp-eyed 13 year old Grandson said "That valve looks crooked". Yup, the #4 exhaust valve spring was broken and sitting cattywampus.
