replace fuel pump on,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: replace fuel pump on,,,,,
    Posted: 02 Mar 2022 at 6:50pm
 My Son's 2002 Hundai Elantra needs to get fuel pump replaced after my gauge set tells me it only putting up 11# fuel pressure. I had him remove the pump as it is Conviently located under the rear seat,,,(what a novel idea,)  and why don't American engineers do the same thing where it don't take an act of Congress to remove the frigging gas tank that is mostly 3/4 tank FULL,,when fuel pump goes out,???
 Anyway, he removed the fuel pump and he went and ordered one. New pump came in today and when I went to install it,, the pump plastic body looked like it was about 3/4" TOO LONG,,,?? The pump body was setting in the bottom of tank and top of fuel pump body was 3/4" above the rim of the fuel tank. I could depress the pump body (several springs inside pump body) enough ( 3/4") to install the metal ring that bolts the pump body to tank,,,,,
 I checked out several UTube videos but none of them say anything bout having to depress the pump to make it bolt up.
 Anyone done this before???
bemer848 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bemer848 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 7:28pm
Joe I have replaced several fuel pump assemblies and that is normal. You have to press them down they have springs that keeps them to the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 8:24pm
The one in my bride's 2012 Escape is accessible by removing the driver's seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:19pm
   Hey Bemer848,,,You Da Man,,,Man,,,!!! Sure glad you did chime in and save my azz,,,cause I was fixin to take this pump back thinking it too long,,,, THanks to you!!!ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:30pm
be glad it ain't a 2014 ? Dodge diesel PU.... springs krap out and unit  sucks.. air that is, even with 1/2 tank of fuel....
NOT mine, hehehe , 'his'......
neighbour cut hole in his cavalier or cobalt..to do the fuelpump exchange...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 11:34pm
spose you can't put an electric one under the hood like the olden days anymore huh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 8:55am
  You know,,Shameless,,,,,you just gettin too dang good bout figurin me out before I decide thas what I want to try,,,,,,LOL   And,,and,,it could be done but it wasn't MY car,,,,or I would have ,,,, They's just a few little "details" i'd have to figure out,,,,but it be "do'able for an old country boyLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 9:12am
 This for the group,,,should someone come up on this and will save you some gruntin and groaning,,,  The pump is intentially made bout 1/2" longer than the tank is "deep". This to keep the pump suction close to the btm of tank and a Hyundai Tecknition told me also to stop the assembly from any movement,,,,Who Knew,,??
 Anyway,,go buy 6 bolts (metric)bout 1" longer than them little bitty short bolts and install in every/other hole to pull the pump assembly down into the tank,,,then,,one by one,, exchange the long bolts with the factory short bolts to finish the bolt down. (Hint,,the tank threaded bolt holes DO NOT go all the way thru to prevent any fuel odors inside car.) This way you don't need 3 hands to push assembly down while trying to install them short bolts.
 Hope this helps others,,,,,Clap
