Recommend a tractor
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Recommend a tractor
    Posted: 28 Mar 2020 at 10:30pm
Looking to setup a new puller. Looking for an open class tractor with these rules
Model must have starting production in 1960 or older
OPEN:
ENGINE BLOCK AND CRANKCASE MUST BE SAME LENGTH, HEIGHT, NUMBER OF CYLINDERS, FUEL TYPE AND MAKE AS STOCK
30% OVER RPM
8 MPH MAX, ANY GEAR
WHEELIE BARS REQUIRED, SIDE SHIELDS & SCATTER BLANKET RECOMMENDED
18.4 X 38 MAX – ANY CUT, NO DUALS OR RADIALS
20 IN HIGH & 18 IN MIN DRAWBAR
Would prefer a diesel but if parts are scarce or modifications are limited gas works as well.
NOT NECESSARILY LOOKING FOR ENOUGH POWER TO RUN 8MPH. Right now running stock class 2.5 mph and wasnt to step it up a bit
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 10:45pm
What kind of tractor do uhave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2020 at 11:48pm
Diesel engine will never make as much HP as a gas engine unless it is turbocharged, which you cannot do. What is the maximum weight you can haul on your trailer/truck ??
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 7:09am
What is the class weight?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 7:39am
If you want to pull an A-C, the newest and largest is a D-17. A D-15 fits the 1960 criteria, but would be a very poor choice. Other than that, the usual WC, WD, WD45, B - C, CA and maybe a UC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 3:39pm
How many cubic inches can the d17 engine be built up to. Ive got a pretty mild 240 in my wd that's competitive in the stock class but want to build an open class tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 3:39pm
As Aaron asked What weight class are you looking at?  2500/3000=CA  3000/3500 =WC 4000/6000 =D17
Edited by PaulB - 29 Mar 2020 at 3:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 4:17pm
D-17 can pull 4250. I regularly pull 4500 and up. Bare weight of mine with 14.9 x 38's is 3800 lbs.
Edited by DrAllis - 29 Mar 2020 at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 8:37pm
U can go over 400 cubes, but the rod ratio gets alittle far out for running 3000 rpms. Stay around 300 and do a lot of air flow work,cam, cam timing,carb work. Get ur head flowing but not to big on valve size. Get manifold flowing good or a header. $$$$$$$ makes hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2020 at 6:12am
At 30% over RPM limit, the best he could do is about 2400 rpm anyway.  I've heard of 400 being common.  Antique tractor pullers may well be like fishermen though.  Sometimes they use a different tape when they are measuring...
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2020 at 9:08pm
3000 rpm is easy to make, I do not run mine that high. But the guys that run open usually don't run a govener. WI50 use to run his WC up to 6000 rpm, he ran around 290 cubes.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2020 at 7:41pm
I had a D17 stretched to 435 cubes
phil
RichinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 5:29pm
My 17 weighs 3640 no driver with 15.5 38s. What bore and stroke are you using to get 435 ci?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 7:57pm
4.7 bore stroke 6.25 strok = 433
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 9:33pm
Must b filling the block, sleaves would b very thin. Custom rods!
