Rebuilding 200 power director clutch
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Topic: Rebuilding 200 power director clutch
    Posted: 18 Jan 2011 at 1:41pm
I am rebuilding PD clutch in a 200. The 2 driving hubs that drive the clutch disc have little worn spots where the disc spines engage to hubs. My question is how much wear can these hubs have and still be usable?  Thanks, Sam
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 1:57pm
I rebuild my D17 clutch a few years ago. The dealer recomemded replacing them with very little wear. He said the discs can bind in the grooves if under a load, and wont shift smooth. If i can find the old gears il try and measure the difference.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 4:45pm
 If youve got over  3/32 deep wear groove sId look at replacements.  The discs need to slide a little on the hubs, with to much groove they can bind which accelerates wear on the clutch splines themselves.     Hope its warmer down there than it is here  +5 right now.   HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2011 at 4:48pm
I'd replace all 9 discs with new 70261212 discs from a 7000....they will never break....put them in my Dad's 200 in 1979 and still works well to this day.
