Reassembly ED40 Gear Box , Need Help
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Reassembly ED40 Gear Box , Need Help
    Posted: 23 Feb 2023 at 4:04am
I am reassembling the gear shift of my ED40 gear box.
how to insert the rod shift and have the springs compressed? It is difficult doing that with only 2 hands?
How to proceed?
Edited by John426 - 23 Feb 2023 at 4:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 7:39am
never ever done one but...
GREASE !
 use thick grease to hold ball and spring ??
I'm sure someone here will post his 'trick'.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 8:29am
is there a vertical pin hole to push the balls in, then slide a wire thru the pin hole to hold 3 balls.... then pull the wire out after rod is installed ??
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 8:42pm
Make a T handle the size of rail. Grind a tapered V in the end to start over ball and spring. Start shaft through holes with  ball and spring. Rotate shaft to push ball down. Move to  next one and do same thing. Next push tool  back out with rail and forks as they are to be assembled.                    MACK
