rear wheel spacing for plowing?
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Topic: rear wheel spacing for plowing?
    Posted: 30 May 2010 at 3:45pm
I have a 5-16 semi mount allis plow for behind my 190XT what should the wheel spacing be on the tractor?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 3:52pm
what series plow?  I may have the info here next to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 4:47pm
To make the plow centered behind the tractor, assuming your right wheel is in the furrow, there should be 80 inches between inside of rear tires. I know they usually measure from center of tire to center of tractor or other tire. If you want to measure center to center add the width of one rear wheel to 80 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:02pm
It is a Allis 2000 monoframe with hydraulic auto reset and sidehill hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 4:00pm
Chris, in my 2000 manual for a 5-16 it shows that the measurement from center of tractor to the inside of the furrow wheel should be 30-31 inches.  The hillside should be in the exact center of range of travel for normal operation. I hope this helps.
Edited by JoeO(CMO) - 31 May 2010 at 4:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 4:24pm
I guess the plow doesn't get centered then. One bottom will be out past the landside wheel.
This page was generated in 0.110 seconds.
