Rad Runoff Tube Repair
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Rad Runoff Tube Repair
    Posted: 03 Jun 2010 at 5:30am
The joint where the runoff tube attaches to the radiator neck on my WD45 has broken. Fan blade sometimes hits the tube at one spot, maybe because of vibration. I'd like to reattach the tube and then see if I can reshape it to eliminate the fan blade/tube problem.
Has anyone had any luck resoldering them while the radiator is on the tractor and full of coolant? Thanks.
WC, CA, D14, WD45
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 9:11am
You need a couple inches of head room to solder, else moisture will boil and blow the solder away. I have a big enough soldering iron that I've tried to solder seams with water present and it did that there too. Once I lowered the level, I had no problems soldering the seam with most of the radiator full.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 10:24am
Good point - thanks for the suggestion.
WC, CA, D14, WD45
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 12:27pm
Be carefull, dont get it to hot or the neck will come out of the radiator!!!!  Use plenty of flux and clean, clean, clean before you solder.   Good luck.
