R62 concave filler bar removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: R62 concave filler bar removal
    Posted: 04 Oct 2024 at 10:38am
What is the procedure to remove concave filler bars on R62? I see the nut and clamp underneath. Do you unhook the adjuster links and lay it back to pull them out the top? The service manual is worthless. Do you fish them out the inspection door by gearbox?
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 12:54pm
Steve, if you open both   doors IN THE HOPPER on the upper back side where you can see the feeder house chain on 1 side and the other will give you light and a view point you should be able to get them out through there, fish them across with a long screwdriver or prybar. Hope this helps and I got to you before you pulled your hair out
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 4:25pm
Thx for the information. Maybe this weekend but needed to know how.
This page was generated in 0.039 seconds.
