R52 Fuel Tank Removal |
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jan 2020 at 10:23am |
Has anyone removed a fuel tank from an R52. Mine sprung a massive leak last night. Do you remove the cab and take the tank out that way or does it go out through the bin by removing the sheet metal?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22059 |
Rivets and thru the grain bin.
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
ug!!
My thoughts exactly.....
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5112 |
must be a common thing. A buddy of mine had his repaired due to agco not having new tanks in stock at the time. Used it a day or 2 and sprung a leak right at the repair, so got to buy a new one, which by then was available, and do the job twice! Sounds like a $h!tty job to have to do!
Found one at a combine wreckers, they told me they have sold a couple...not cheap price they gave me. Thinking when I get it out I may make one out of aluminum, then I wont have this leak appearing when I need it. My luck things like this usually happen twice...just like your friend Ed...
I will decide when I get the old one out. I am curious how come it started to leak, and leak like a fire hose when it did. i would have lost an entire tank of fuel if I had not just happened to walk past it last night.
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Sounds like an extremely poor engineering job to me!
Allis Express participant |
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
i'd look in to see what maybe had rubbed it. I also think i'd have bought a new tank, the used ones may not last long either unless you can find the reason. sounds like you are in for a heck of a job!
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3571 |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8654 |
Those tanks won't fit a rotory
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
thinking out loud here ... could you adapt a semi fuel tank ? or some SS tank ?? sounds like they all fail....but why ? vibration ?? rubbing ?? unless the cause is found 2nd one will fail by the sounds of it... putting in a used tank buys you some time, a new tank hopefully more but.....the clock's ticking down......
"Sounds like they ALL fail "? I don't think so. I've never seen one fail yet and R-40/50's have been around since 1987. They are a poly tank and I guess the first thing I'd NOT DO, would be let it sit around 9 months out of the year full of fuel, to relieve the internal pressure of the weight of the fuel against the tank structure.
Oddly enough, the R52 in my above story happened last season, and an R62 here in our town had the same thing happen. So for the few around here, there seems to be a pattern starting. It seems to me is was at a seam, but I do not know for sure. Definitely worth looking in to to make sure nothing is rubbing that shouldn't be.
LB0442 ![]() Orange Level ![]() ![]() Joined: 27 Dec 2014 Location: Boise ID Points: 767 |
I had a black water tank on the 5th wheel develop a leak, looks like the same material as these fuel tanks. Pulled it out and it was cracked along a seam. New ones were ridiculously high priced so I went to a plastic tank manufacturer, not too far away, just to check on them making one and they said they could plastic weld it. The repair looks great and it's been 3 years now, still holding. Just another idea for you. I think it was 40 bucks for the repair. Had to clean it out real well first though.
hmm.. 'plastic' tank... wonder if the 'rubber' isolation/mtg straps wore and rub-a-dub-dub... wore a hole into the tank ?? I'm betting very few actually inspect the tank and it's mounting 2 x a year..... I KNOW I ain't never crawled under my F150 and it's on it's 2nd set of gas tank straps...
I already have a tank off a truck that I can stick in the combine if I decide to go that rout. Definitely it is the most cost effective way to go, and I know I won't have any trouble with it in the future, I have lots f those tanks around doing various jobs, that have been here for my entire life. When I get it out I will show you what caused the leak and I will decide then what I am going to do with the problem. I may just build an aluminum tank that fits in the same place...will decide when I see why it leaked
hmm.. depending on size/shape/access maybe an air compressor tank will work ? I'm also thinking the 'saddles' need to be 3-4 inches wide with say 1/2 hard rubber cushions. Aluminum tanks may be fine for semis on the open PAVED road, but combines tend to be driven 'offroad'.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
N-5 plastic tanks also sprung leaks!
Jim NEIN ![]() Silver Level ![]() Joined: 12 Nov 2010 Location: Indiana Points: 280 |
You said you did'nt lose much how did you get it stopped or did you drain it in a container.
I started a siphon with a 1 inch hose I had through the fill into a portable tank in my pickup, Had to pump the last twenty gallons, as siphon hose started sucking air, the tank had been full and when I stuck the hose in there was still a little fuel in the fill tube below the cap. Lucky I walked by when I did, or I am sure it would be empty before the sun came up.
Edited by Amos - 12 Jan 2020 at 5:15pm |
