R40 question
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: R40 question
    Posted: 20 Jan 2011 at 6:54pm
Just talked to my uncle about his R40 and his only complaint was when it gets down to the freezing mark it gets hard to start without using ether. It doesn't have any kind of preheater. I don't remember what was used on those. Some kind of manifold heater is my guess but can't remember. Any suggestions? Thanks. Lonn
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 7:37pm
They get like that with age. I've relocated the ether injector nozzle ahead of the air filter and put it on a button of it's own to give it a shot just before cranking and to maybe hit it again if needed. Located farther from the engine it doesn't knock nearly as bad and we replace the air filter seasonally anyway. Stay away from John Deere (80%) ether and use cheaper stuff to soften the blow.
