Questions about a 200
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 10:01pm
So, how do you factor in the 3450 psi injectors on a 200 engine to 2900 psi injectors on an older 190 XT engine  ???  I see in my Service Book a 190 XT with 2900 psi injectors was set at 65.5 to 67.5 cc's @ 2,200 RPM. A newer 190XT with timing advance had 3450 psi injectors and fuel setting was 71 cc's.   All 200's were as you say 70 to 72 cc's but also with the higher 3450 psi injector settings.  After all the rear end problems I don't think their goal was to increase HP. They were maintaining HP with higher injector pressure settings. Dyno a 190 XT with 2900 psi injectors and then re-test (same day, same air temps and humidity) at 3450 psi. No way will you gain HP....it will have to show some HP loss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 10:35pm
My neighbor bought a 1974 200 for $1,200. It needs engine rebuild but the rest of it looks pretty good. Of course he is taking the sellers word that trans/power director is good. It will be a parts tractor for his other 200 if things dont check out. For $1,200, I Hinkle he did well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 10:52pm
The 200 has the improved rear end, other than that I’m not convinced the 200 is a better tractor. The 190XT is a simpler machine with nearly the same hp. In some ways I like my XT better than my neighbors 200. Not a fan of the short shift power director and they seamed to have had more issues. The longer throw PD on my XT makes it much easier to feather starts when running a baler. No doubt the 200 is a good tractor, especially if you find a we’ll maintained one.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 7:15am
I certainly learned a lot from this thread despite it wondering away from Wilfords original topic. Thanks drallis and injed. I think Wilford is new to the forum and probably thinks we're a bunch of kooks. Redbank if you drag a 200 to Indiana, you are welcome to stop by.
Wilford1999 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilford1999 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 7:29am
I have been looking stuff up on this forum for a few years, just never made an account.I just absorb all the knowledge being shared.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 7:59am
Wilford did you make an offer or did we scare you away from it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 8:21am
Wilford, that's good and glad to see you post. You already know how this can go since you have been lurking. I have been trying to engage more since I have benefitted greatly from this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilford1999 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 8:47am
The guy deleted his post, so I'm assuming he sold it or got tired of people coming to his house cause when I called him he said he had a lot of tire kickers coming to look at it.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2018 at 7:37pm
The specs I have are the Stanadyne specs, and they are all set with 2500 psi 12SD12 test injectors. I've found over the years, the pump will still pump similar quantities, even at varying opening pressures. The increase is opening pressure was attempts at cleaning up smoke. Remember in those days 3000 psi was a lot. The 2800 engine was 2850 psi, but turbo 2900 was 3150, by the books I have, for XT & 200. The 7000 shows 3700 psi for AC or Bosch inj, 7010/20 show 4050psi for AC inj, 4000 psi for Bosch. Back then they didn't know how much the pumps could withstand lol!
Edited by injpumpEd - 25 Jun 2018 at 3:01pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 2:51pm
Originally posted by Amos Amos wrote:
It has a notched plate  The plate wears and you replace it or build it up to get the lever to move far enough and to stay in place
The first 200's had the PD lever like the 190. Later ones used the notched plate. A common problem on the early ones was linkage  wear that caused the power director valve to not fully engage.
There is a side plate that the PD valve bolts  to on the right side.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 7:08am
Alright, I remember reading in the Allis-Chalmers bible, Norm Swinford's book I think, where the 200 was company tested at around 105 PTO HP. AC didn't want to spend the money to retest at Nebraska so they sold it under the original 190XT specs which allowed the 200 to be sold in Nebraska without being tested. Nebraska law requires or required testing at the U's testing site before a tractor could be sold in the state.
I don't know any facts, I wasn't there but I'm going to take Norm Swinford's book as true at this point.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 12:28pm
I never knew that Nebraska required the testing by law.  I just assumed it was a moneymaking scheme by the University.  That also explains the missing 200 test.  Thanks for that Lonn.  I guess I need to read that Swinford book.
This page was generated in 0.107 seconds.
