question
TerryMtAuburnIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Topic: question
    Posted: 11 Feb 2012 at 5:46pm
I need the torque specifications for the head on a 16 hp Kohler, by the way it'a an Allis Chalmers 916
Thanks for the help, Terry
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 6:16pm
  we torque ours at 400 in. lbs  it is a little over but will not hurt it   clean bolt holes and threads good also
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 8:23pm
I think this link will be helpful to you!
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 1:43pm
ok thanks but what is 400 in. lbs.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 1:59pm
   400 in. lbs. = 33.33 ft. lbs.
http://www.rumelyallis.com
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:34pm
If you look in the service manual I posted, you'll see that it says 25-30 ft.lbs for the head bolts.  Just like norm said, the 400 in. lb. (or 33 1/3 ft. lb.) spec. is a little over.  I've never had a Kohler apart. so I can't speak from experience.  You should follow the sequence that's given in the service manual.  It's important, too.
