Question for Lowell66dart on gear reduction starte |
DIESEL
Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
Topic: Question for Lowell66dart on gear reduction startePosted: 29 Jan 2020 at 8:15am |
![]() I got a gear reduction starter hooked it up and I have nothing. Did you run a seperate ground to the new starter, I figured it would pick up ground through the bolts. Thanks |
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Posted: 29 Jan 2020 at 9:20am |
I ALWAYS run the ground to one of the starter mounting bolts. I don’t have the tractor anymore so I can’t look at the wiring.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
lowell66dart
Posted: 29 Jan 2020 at 9:26am |
Do a search here for 7000 series gear reduction starter. It will show you how it’s wired. That big lug on the bottom is the ground lug. From your pics you have it wired wrong
