question about d-10 grille
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Topic: question about d-10 grille
    Posted: 17 Nov 2011 at 8:24pm
does anyone know where you could get the stuff that goes around the edge of a series 1 or 2 d-10 ir d-12, I made a grille out of a torn up d-19 grille and it turned out super sweet, but need that stuff to finish it and I dont even know what you would call it .thanks, Dustin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 9:02pm
Dustin, if that is the rubber-plastic stuff, it is an edge ease. Should be able to get it at McMaster-Carr. If not there is probably a supplier of it on the net. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 7:45pm
tracy Thanks for turning me onto that place .  Found the edge stuff and it matches with the 3 others almost exactly and it was cheap @ less than a dollar a foot,  and if anyone is needing some it takes over 5 1/2 foot to go around a d10 or 12 grille so you better order atleast 6 foot, Dustin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 8:43pm
Dustin, you are more than welcome. Some here have been very helpful to myself, and thank them for it. Tracy Martin
