Putting a transmission behind a 301 |
simplemanlivestock
Joined: 30 Aug 2019 Location: Scottsbluff, NE Points: 3 |
Topic: Putting a transmission behind a 301Posted: 30 Aug 2019 at 3:34am |
I'm in the process of gathering parts for a rat rod that I'm putting together for a national build off. It's a 301 from a 7020 tractor. Does anyone have experience with putting a conventional transmission behind one? I'd like to run a Spicer 6+. Where I'm running a 2 speed rear from an old farm truck, the 7th gear overdrive in the 6+ will give me excellent low rpm highway cruising speeds.
Michael V (NM)
Posted: 30 Aug 2019 at 7:02am |
find a power unit with a sae bell housing... I've been interested in something like this, but building a gooseneck toter, but using an Allison auto..Google fuller transmissions, you can find out all kinds meet stuff such as ratios, trans weight, etc.
Edited by Michael V (NM) - 30 Aug 2019 at 7:07am |
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 30 Aug 2019 at 7:09am |
Couple guys have put them in pickups. Search YouTube.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35664 |
Posted: 31 Aug 2019 at 10:00am |
Biggest concern once adapt to Automotive is fuel system, the tractor pumps do not have advance/retard mechanisms as far as I am aware and cannot adapt to altitude changes. May want to look into that as well.
simplemanlivestock
Posted: 01 Sep 2019 at 12:54am |
Thanks for the input. I plan on running a p7100 pump from a 5.9 Cummins I found to make it more drivable. As far as a transmission is concerned, I think I'm going to end up with an NV4500 5 speed from a Dodge pickup. I'm beginning to think this is my best option...?
