pulling a 7000 series allis |
timmypuller
Joined: 01 Apr 2013 Location: wardsville,mo. Points: 125 |
Topic: pulling a 7000 series allisPosted: 21 Jul 2013 at 4:40am |
can you take a d21 210 or 220's transmissions and put in a 7000 series allis? don't know a lot about this series but only 1 that pulls in this area sounds like hell because howls so bad. i think its the power director trans making all the noise. found 7040 cheap brother thinking of buying and building into puller . power director trans is bad and we would rather just set it up like my d21 if possible
DougG
Posted: 21 Jul 2013 at 5:06am |
Dont think that will work, 7000 series are totally different than 21,s,210+220 ;those things are so heavy to begin with, alot of stripping needs to happen; gutting the PD and run a straight thru shaft can be done to by pass that problem
Edited by DougG - 21 Jul 2013 at 5:09am |
Posted: 21 Jul 2013 at 8:27am |
There is not one single part interchangebale in the driveline between a 7000 series and a D21. The 7000 series driveline does not normally "howl", so there may be some custom made gears in it. It also could be a D21 chassis with 7000 series hoods.
