pullers
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 1:02pm
A video from the pull at Hutchinson 2010.  http://www.youtube.com/watch?v=aLolOQM3kOM
Allis orange blooded by family. Allis Diehard by choice
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 1:43pm
Benny, Do you pull at the fair or just at the antique show? I haven't ever pulled at either with full size. I've pulled garden tractor at the fair a couple of times but this year I'm thinking about pulling at the antique show.
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 2:20pm
Here's what is now a fond memory!!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 4:24pm
I hear is in ohio getting a chevy v8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 4:34pm
That was 'ol Barn's plan....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 4:59pm
Yeap his 14 degree sbc runs  well
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 6:58pm
iv seen this tractor right above me pull in mufresbro at millers colliseum am i right
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:25pm
I pull at both, and a few others....anything you need to know just ask and I'll try and fill you in....only thing with the Antique show is you cant hang weight, and you can only pull one time per tractor you have there.....still alot of fun though. The fair is a good time as well...check out http://cptpa.yolasite.com/ for rules that they use....that site is for Central PA Tractor Pullers Association which I'm a part of....we have monthly meetings and what not....and I'm the only Orange guy in the bunch lol....and just out of curiousity, by your screen name I'm guess you're a Bald Eagle Boy? I'm not picking....BEA class of '01
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:29pm
Yup Bald Eagle. Class of 10 lol I'm hoping to pull my MD if I ever can get my hand clutch adjusted right. It wanted to slip real bad when it was hooked to my Uncle's JD 60. I might even get the allis in there I"m not sure. If you've ever wandered over toward the garden tractors you would have seen my Speedex's there. I've been taking at least one over for probably 6 years now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:39pm
Nice....do you have a big enough trailer to get either your MD or AC over there? And I'm guessing you're referring to a Farmall when you said MD? I can hook you up with a few guys over this way that can probably get you fixed up with that clutch problem.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:43pm
For the trailer, we have one but I can't put the Farmall on it. It has fenders so I can't get the wheels in far enough. It has the capacity to haul it but not the width. My pap has a real heavy deck over that I use but it weights 3300 so with the farmall (weights and fluid, plus wide front end) that puts me really close or over weight. It hauls it ok just I don't want to get stopped. The allis should be no problem. I might even put the allis and our ford 8n on the same one. For the clutch, it has the M&W hand clutch so I can have live PTO for baling hay or whatever. I've already tightened it so I could plow with it and by the end of our little fun pull I had it adjusted pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 7:46pm
If there's a will, there's a way! But bring the AC over.....not that many come to the antique show and next to NONE come to the Grange Fair.....I'm really really hoping to have my WD45 done for the Spring Gas Up at the Cave
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:01pm
The CA will definately be at the fall show. Not sure about the spring one. I normally never take anything over since it's not that big. might have to save a spot so i'm not parked by some creeper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:05pm
Bring it out to the spring show....its getting bigger every year and the pulls arent quite so over run with the thousands of tractors that come to the fall show....Since you're close I'll try and keep you up to date on pulls I know of....most you would have to take the Farmall....alot of pulls start at 4000 or 4500....the antique show weight class's start at 3000 I think so the CA would be good to go.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:13pm
ok. sounds good. I always had prom the weekend of the spring show so I never spent much time over there. Since I"m out I'll have that weekend free. We don't take our camper over in the spring so i'll have to drive over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:15pm
We'll have to meet up sometime and I'll show you how my WD is coming along....I live right outside Centre Hall.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:20pm
Port Matilda. I'm in state for college everyday. If you ever need another hand let me know. I'm around. done with class M W F at noon. Tuesday I'm done at 6 (long ROTC day) and thursday at 3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:22pm
Nice....I'll let you know sometime I'll be at the shop and you can come check things out....
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
180Puller View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:36pm
180 Allis on alky.It broke a crank on its first pass in 2010 and I have waited 7 months on billet main caps and a girdle which recently arrived.Hope to be up and running by late May.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 4:48pm
Kendaks little ci giant killer.
ACB110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACB110 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 4:19pm
Aunt Allis AC 200 Gordyville 7000 lbs. Limited Pro Finals Winner
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 5:50pm
Heres as close to pulling I have gotten. uploads/2813/2795402463_018_2091.jpg
jeffnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 6:41pm
220 farm stock on previous picture, 220 640 pro farm hopefully ready for summer of 2011
Todd Domann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Domann Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 7:56pm
Jeff,
I think I met you and your family at Henry in 2009.  Good luck with the winter upgrades to the 220.  From the looks of this photo your driving days may be limited as the Boys will be chomping at the bit to get in the driver's seat.  Take Care, Todd
