PTO drive shaft hook-up problem
Rod Yowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Topic: PTO drive shaft hook-up problem
    Posted: 16 Jun 2012 at 5:59pm
I have completed the replacement of the torque tube and pto gear box. I am trying to hook up the drive shaft to the pto box. It will only go in half way. I have lubed it up several times. I have used a wood block & 4lb hammer to try and tap it in but no good. I am afraid to keep pounding on the shaft, I am worried about damaging the gear box.
   Has anyone else had this problem?
Socialism is the Philosophy of Failure, the Creed of Ignorance, and the Gospel of Envy
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 6:14pm
Rod, might be good to say what model you are working with.  Sounds like burrs in the pto where the bolt goes thru if it's a WD or 45.  This would not be the case on other models.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 6:38pm
File the burrs off the out put shaft and feel around the inside of the PTO shaft for burrs. Might need a rat tail file inside. Flapper wheel on a die grinder might get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 8:31pm
Sorry, I should have said I was working on a WD45.  I thought that I had asked enough stupid questions by now that most people remembered me as the dummy trying to play tractor mechanic with his very first tractor (WD45).
    I thought the PTO shaft might need to be ground down a little because it looks like it might have be welded on and ground down before I bought it.  I let my wife talk me into proving I am as dumb as she thinks I am and try to hammer it on one more time while she 'helps'. So now it is stuck half way on. I gave up on it for the night. I will try again tomorrow with heat and hope I don't burn my garage down.  If I manage to get them apart, I will take the PTO housing off and take a grinder to the PTO shaft, remove the short shaft from under the 3 point hitch and get it to hook up on the work bench before I try to put them back on the tractor.
   Thanks for your suggestions fellows. It helps a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 8:34pm
Leave the grinder where it is and get a file. Use the best light and your good eye to find where it was binding and file it off.
