PTO bearing shims |
Pete32
Topic: PTO bearing shimsPosted: 24 Feb 2018 at 9:29pm |
After two days of struggling with the PTO oil seal on my WD, I finally won. It's a good feeling. I had to take the PTO cover(bearing cage?) off to get it out. One of the paper shims paper shims tore when i was taking it off.
Are the paper shims also used as an oil seal or are they just used to maintain proper clearance? Can I reuse it? The one that tore was up against the PTO gearbox. Are the paper shims still available or do I have to cut them and what material would I use? I'm pretty green when it comes to this stuff. Thank you- Matt
Dave76
Bronze Level Access
Joined: 26 Mar 2015 Location: Hebron Illinois Points: 75 |
Posted: 24 Feb 2018 at 10:12pm |
I would get new gaskets they are available from DJS Tractor Parts. You might need two or three for correct gear spacing.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5197 |
Posted: 25 Feb 2018 at 7:36am |
Those shim/gaskets are the same that any standard 6 bolt truck PTO uses. They are available in thick and thin ones, use as needed to get the proper gear backlash.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4200 |
Posted: 25 Feb 2018 at 9:15am |
I've gotten them from Agco, price was reasonable.
