PS Torque Limiter Double Spring
Message Reverse Sort Order
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: PS Torque Limiter Double Spring
    Posted: 09 Sep 2025 at 7:58am
If everything is new and to specs, it really shouldn't need a double spring. Double springs won't slip, but can eventually tear out the center hub. I have occasionally taken the flywheel to be surfaced and have the shop change the recommended step dimension to about 10 to 15 thousands less.
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2025 at 4:13pm
Getting ready to slide a 670HI into my 8050, and trying to decide how i want to install the torque limiter. I had the flywheel machined and have a new TL disc, spring, and plate from Agco. Read a few different places about stacking 2 Belleville springs and using 1/2" lockwashers on the bolts, is it a safe or "recommended" thing to do or should i just put it back as stock?
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
This page was generated in 0.305 seconds.
