Prototype D17 D alternator
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Topic: Prototype D17 D alternator
    Posted: 26 Apr 2011 at 8:11pm
Finally got done with a prototype alternator/power steering pump I needed for my D17 D. When I bought it there wasn't a pump on it and I knew that would not work. so I mounted a power steering pump onto it and powered it with a drill to see if the power steering would actually work which it did. would have been nice to put a factory one back on but when I saw one on Ebay go for 250 dollars so I figured I would try and make one first. now just have to hook it up and try.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 8:55pm
That's a great idea !
Looks like something that could be made into a kit form and marketed to the many users of D17s that've had problems related to that gen-driven pump.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 9:14pm
I like it! Looks like it should work fine. Let us know.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 9:57pm
I was fortunate and had all the parts laying around. the hard thing is to find an alternator that has a shaft coming out the back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 11:32pm
Do you know what the alt came from? I figured an alternator was out of the question with the gen mounted pump.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 7:10am
There should be a number on the alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 7:25am
You'll find some Delco units that drive pumps on Forklifts. I've rebuilt some units in the past that sport a pump on the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 7:29am
How well does it fit under the air cleaner and drip shield?
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 9:03am
I did look for a generator/ pump off a fork lift for I seen many junked in my day but actually the only alternator I could find with a rear shaft was one for an Isuzu diesel engine. the one with a smog pump mounted on the back. It is 50 amps which should be just fine for a tractor and actually it isn't much larger around then the standard generator. My nephew used to be a Isuzu man and had one in his shed he gave me and the pump was inside a old car I scrapped. I'll post the outcome once I get it hooked up. but even if this prototype fails, my mind still has some ideas. Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 7:13pm
for those that are interested, I HAVE POWER STEERING. From all preliminary testing my prototype pump/alternator works good. I dug some holes with the front tires in the dirt so I figure it will work on the role. I still need to bracket it in properly and hook the alternator up, but I just LOVE that power steering. You might not think about it but it's a bear without it.
