Power Units
denwic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote denwic Quote  Post ReplyReply Direct Link To This Post Topic: Power Units
    Posted: 18 Oct 2010 at 9:17pm
Have found a A-C power unit, big gas 4 cyl., was used to pull sawmill has belt pulley, engine loose, all there but hood, but do have side panels,hand crank, what is it?
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:21pm
If it looks like this unit belonging to Chad (WI) from this site, it's an E-60.
are genuine." - Mark Twain
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:51pm
If it's significantly smaller, it could be a B-125. Same engine that was used in the B, C, and CA tractors. Got any pics? That would make it a heck of a lot easier to identify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 10:00pm
I can picture a B-125 on a shingle mill, but I can't envision one on a sawmill. A pic or two would help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 10:55pm
I can't either, but I thought with the vast production its worth a shot. They are crawling all over these parts, I don't think I've ever seen anything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote denwic Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:29pm
The E-60, thats it, after seeing the picture went back and looked on side of raditor and there it was, thanks ya'll I'm not too A-C familiar, more JD, but like anything old, this power unit and a sawmill were saved from the torch, but too late for 2 tractors and some farm equipment, don't know what the tractors were but one had a front end loader, what a shame. Will try to get some pictures posted, was this engine a power unit only or was it in other things?
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 8:50am
I have seen the bigger power units, but never seen them run. Did the e-60 use the 201/225 engine or the bigger A engine?   With the shields on the sides are they quieter than the equivalent powered tractor?
That set up looks like it would be hell to get the belt tension just right and every thing lined up since you cant roll forwards or backwards.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 4:13pm
Ask Fred Lucabaugh about big Allis power units.
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 5:34am
Same basic engine, but bigger bore than the A - 5 1/4 X 6 1/2. I have an Allis EK 30-60 from 1935 which has the same engine in kerosene trim. Massive torque and power from those 563 cubic inches.
Tricky Dickie
Edited by Tricky Dickie - 21 Oct 2010 at 5:35am
