power steering pump conversion
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: power steering pump conversion
    Posted: 22 Aug 2023 at 9:43am
i have d 17 gas tractor for parts,        can i use the power steering pump from the d17 on my wd and a charlyn torque generator i would need to change my mag to a distributer
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 10:12am
I have thought about doing that too, but you will need a reservoir tank too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 4:55pm
i have thought about useing the wd 45 power steering tankor running off of the hydralic resivior  where my remotes return
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 9:21pm
Best to find a pump from older car or truck that is about like yours. Most older D17 pumps like that are on their last leg. If you have a good parts man at your local auto supply store, he can show you pictures to compare to yours.                        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 10:41pm
i do have a eaton belt drive pump but no brackets and pullys for the front of the engine
This page was generated in 0.152 seconds.
