Power director clutch on D-17
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Topic: Power director clutch on D-17
    Posted: 04 Feb 2011 at 7:50pm
I know this has been discussed on here before, but what do I look for when the P.D. clutch lever does not want to stay engaged, especially when the oil is cold. The clutch does not slip and will stay engaged when the oil is warm. I have the clutch out but only see minor wear on the pre-load plates. The rollers don't have flat spots but could have some wear. The release levers look OK.
                                        Pete
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 7:58pm
you need to replace the ring that the rollers seat in   without seeing unit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 8:47pm
Thanks Norm. The book calls those pre-load plates. The ramp on that plate has some wear. Could the rollers also be worn and adding to the problem?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 8:50pm
Take a grinder and grind the wear marks out of overcenter plates. Cheeper than a new set and some times better.   MACK
This page was generated in 0.158 seconds.
