Plumbing |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Topic: PlumbingPosted: 16 Mar 2025 at 1:48pm |
Replaced a leaking toilet fill valve today. Pretty easy peasy, but kinda crazy how many different ones the big box store has. Glad I knew which one I needed.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 16 Mar 2025 at 2:15pm |
I try to be like NOAH, get TWO of things like that , so I have a spare when needed.... ..like 2AM when you are fed up of the drip..drip.drip...drip.drip...........
ACinSC
Posted: 16 Mar 2025 at 2:22pm |
Yeah Jay, I've done the same when we lived out in the boondocks. Now I'm much closer to big box stores. Thanks
jaybmiller
Posted: 16 Mar 2025 at 2:26pm |
OK.... but I don't want a phone call at 2:01 AM anytime soon !
Joined: 11 Sep 2009 Location: illinois Points: 90821 |
Posted: 16 Mar 2025 at 3:56pm |
I bought one last month that had this litte RED BUCKET under the valve body.. Seems like it is suppose to fill with water and hold the valve CLOSED.. If the toilet drain leaks slowly, the bucket keeps the valve from constantly opening and filling the tank.. When you trip the HANDLE the bucket is attached with a chain and it tips and dumps.. allowing the valve to open and refill the tank..
WORKED LIKE CHIT.... Could not get it set right.. Finally threw away the bucket and just let it work OLD STYLE..... I like these with the vertical float, as compared to the old "arm and ball float"...
plummerscarin
Posted: 16 Mar 2025 at 4:59pm |
Those early ones we dubbed "Floodmaster" as they had a tendency to pop loose and well you know. I think they are better now but be darn sure the lock ring on the height adjustment is properly snapped in.
ACinSC
Posted: 16 Mar 2025 at 5:03pm |
Haven't seen a arm and float ball in a long time. Do remember them. I've always had good luck with fluid master. Thanks
