Plow for AC 170-175 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Plow for AC 170-175 ?
    Posted: 29 Jan 2025 at 7:59pm
What size plow were sold with the 170-175 tractors? Would 3 -16 be too much? Thanks, Tracy
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 8:17pm
a 3-16" would be a good size for a 170 or 175. You could probably do a 4-14" depending on soil
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 8:38pm
3x14 in western Pa
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 8:51pm
Just for fun- My grandpa hooked up to an Allis 6-16" with his 175 diesel.
And if I didn't see it with my own eyes I wouldn't have believed it. He pulled that plow across the muck ground and did it!
I have pictures of this on my old phone, if I can fine them I will post it
Galatians 5:22-24
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 12:06am
Either 3x14" or 3x16" of either fully or semi mount style should work well in most soils. Fully mounted you'll probably want a set of front weights when lifting it out of the ground.
 A 4x14" semi mount steerable will work in most corn stubble.
 Good plow lays will make having plow go in & stay in the dirt a lot easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 4:37am
I have an original 3 x 16 three point AC plow, If you are interested...   PM me for details...
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 6:31am
Asking about plow sizing is kind of like asking how long is a piece of string. No real answer. So much depends on ground condition, soil type, plant structure (sod? alfalfa? grain stubble? burned down with 24D or still growing?), dryness, hills, etc. I always get a laugh when some folks claim their 50-60 HP tractor will pull something like a 4X14 with ease, and then you find out they're pulling in grain stubble. To me, the measure of a tractor's plowing capability is how well it can pull the plow in sod (and probably alfalfa to boot, which is really tough with it's long/thick roots).
I'd generally agree that 3X16 would probably be a good match for a 175. In light stubble it wouldn't even feel it. But in hilly clay with sod or alfalfa, it'd be a different story. At my father's farm, for instance, any of our 50 HP tractors will walk away with a 3X16 and not even break a sweat even in sod because it's nice, light, loamy soil. At our farm an hour North of there where we mainly plow fresh hay ground, and where it's much tougher, steeper, and rockier soil, the same 3X16 can bring our 180 or Ford 6600 to its knees. The White 2-105 is a much better match.
Edited by DanielW - 30 Jan 2025 at 7:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 6:33am
Please Google:   Dr Allis plowing at the Brown Farm 2024 u-tube videos.         bobschannelob there are several plowing videos from last April.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:22am
This the one you're thinking of Doc?
As to the original question; Tractor data does not give a plow rating for the 170/175 tractors but a series 4 D-17 is rated as a 5 plow tractor. My thinking is a lot of 4 bottoms were probably sold new with them. 14's mostly with a smattering of 16's.
In today's world if you have a nice 3-16's that would be a good match. Probably aren't looking to turn 40 acres a year with it are you?
Edited by IBWD MIke - 30 Jan 2025 at 7:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:24am
Probably. It must have offended someone. It's been taken down. There are at least 4 videos of last springs plow day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:32am
It's still there, not sure why the link isn't working.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:45am
All 4 videos are still posted. Here is video 2 from the Brown Farm 2024.
https://m.youtube.com/watch?v=2EyyflZB7M0&pp=ygUbZHIgQWxsaXMgcGxvd2luZyBicm93biBmYXJt
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:47am
try editing your original posting’s weblink? I see one issue with it “ YouTu.be” should be “YouTube.”
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:58am
One thing I will say about plowing with any A-C tractor (D-17 IV up thru 200) that has a factory 3-point hitch, the chances are pretty good that without some attention, the Traction Booster linkage will be mal-adjusted or missing or stuck, and therefore the TBoost system won't work. Also a very good chance the torsion bar system that signals the Traction Booster will be worn out as well.  I can take a 3 x 16's mounted plow on a 180 or 185 without fluid in the rear tires and struggle to pull that plow with a non-functioning Traction Booster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:59am
The video is still there, link in my previous post is messed up and I can not seem to fix it. Here's a link to the channel, maybe;
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 2:47pm
We ran a JD 4x16 semi mount on our 175.  We had pretty sandy soil though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 3:31pm
Back to the original question "what size plow were sold with 170-175's" ??  Each piece of advertising literature always had a 4-bottom plow hooked to these tractors. Pretty easy to tell if it was 14" cut on a 70 or 80 series and it was just that. The D-17 was the same way. And I know there are parts of the country that 3 x 16's was more prominent because of soil types.  56 inches of cut down to 48 inches with the 3 x 16.
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 7:47pm
I think a 3-16 plow with neither tractor would be a good match specially with fluid in the rear tires and some suitcase weights on the front of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 9:13pm
I have all sorts of AC plows. I was wanting a AC Monoframe . Been looking for a reasonable priced one. I was wondering how they pulled relative to a semi- mounted versus a fully mounted? All opinions are welcome. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 9:48pm
A 3 or 4 bottom fully mounted will pull easier. The longer and heavier the plow the harder it pulls. Monoframe not in 14 inch bottoms.
Edited by DrAllis - 30 Jan 2025 at 10:12pm
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 11:39pm
https://www.facebook.com/share/p/1PnNU6VwzH/
Here ya go, hope the link works for ya!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:57pm
Michael I had seen that one. I think that is too much for it, at where it is located. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 7:21pm
Damn , that's a plow
