Please Identify Part
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Topic: Please Identify Part
    Posted: 02 Oct 2011 at 3:16pm
Not sure what this is?  Received it with my WD-45...there appears to be a spring inside the tube???
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 4:40pm
I'm going to guess it's a hand crank extension. Am I close?
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 10:16pm
Some kind of over running clutch for a PTO shaft ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 7:18am
I can't tell the size of the center shaft. Could it be an extension for a crank?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 7:44am
Without knowing the dimensions I'm going to guess a crank handle extention for using a mounted corn picker or other front mounted equipment,  although an electric start tractor should not have needed it. LOL
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 7:47am
Paint it green and yellow and put it on Epay!  You'll be rich!!!  :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 1:42pm
This thing is about 25 lbs, roughly 20" long, and the inner diameter is about 4"-6"
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 1:51pm
Pat that is exactly what I tthought when I seen it.  Looks like the "crank handle postion extender" is a better probability. Now, question is, what are you gonna do with it?  Is it for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 2:00pm
crank handle postion extender - used on what???  If I can't find a use for it, yes it's for sale...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 6:31pm
It wouldn't be a crank extension if the Id is 4-6 inches.
This page was generated in 0.215 seconds.
